Horizontal section is performed in Right, Left, Front and Back views and in the result view of vertical section.
Horizontal section performed by 2 points. First point determines vertical plane of section (middle elevation point). Second point determines the section.
Create horizontal section:
- Set Right, Left, Front or Back view or the result view of vertical section.
- Run Horizontal section.
- Specify the middle elevation point of section.
- Specify the depth of section.
- Select needed view to display the section.
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD software tool for Windows, that delivers a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program supports progressive, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
