The command copies the Z coordinate value of a block to its attribute and vice versa, and also swaps the Z coordinate and attribute values.
| Action | Copy attribute to coord Z – fills the value of the Z mark with the value of the selected block attribute (only if the attribute has a numeric value). Copy coord Z to attribute – fills the selected block attribute with the Z mark value. Swap attribute and coord Z – is selected in the case when the attribute value and the Z mark value should be swapped. |
| Block | Block selection. |
| Attribute | Attribute selection. |
