Script (only the BeforeConnect and OnConnect procedures)
Other can be seen in the database of the standard details.
// For flange necessary to geometric constraints
// Have been installed on the gasket and parametric -
// The second flange.
function OnConnect {
// When setting dependencies on multiple objects, we first
// Store information about objects,
// And then use it to install, depending
// So, the first stage – the selection of the parameters
// Here rPart is 0 (the serial number of the query begins
// 0.
// If this is the first request, and the selected object = laying GOST 15180,
// Save the parameters of the object (pads) under the number 0
if (rPart 0 & & obj.strTheName “ GOST 15180-86 “) {
setWorkId (0, obj.objectID);
Handled = OBJ_HANDLED;
// For the second request – check further whether this
// Object flange GOST 12821, and, if so, to save the parameters of this
// Flange at number 1.
if (rPart 1 & & obj.strTheName “ GOST 12821-80 “) {
setWorkId (1, obj.objectID);
// Then consider the stored data objects:
// If something was preserved in the first stage, that is, the data is not equal to 0
if (getWorkId (0) = 0)
// Restore the data object variable obj 0
getObjData (getWorkId (0), obj);
// Closest to the insertion point plane
strNearestPlane = GetNearestPlane (pntOrigin);
// If the plane had been found,
if (strNearestPlane! = UnknownValue) {
// We set the geometric constraints of the insert.
SetGeomConstraint (INSERT, CONTRDIRECT, obj, WP1, strNearestPlane, 0, TRUE);
// Do not choose a direction vector
NoVectorSelect = 1;
// If in the latter case the data has been stored, then:
if (getWorkId (1) = 0)
// Restore them back to the variable obj
getObjData (getWorkId (1), obj);
// Set a set of parametric dependencies
// In nominal pressure, nominal size,
// Form with a cut flange Series and a number of performances.
SetParamConstraint (Py, obj, EXPR, “ obj.Py “, TRUE);
SetParamConstraint (Dy, obj, EXPR, “ obj.Dy “, TRUE);
SetParamConstraint (bSection, obj, EXPR, “ obj.bSection “, TRUE);
SetParamConstraint (R, obj, EXPR, “ obj.R “, TRUE);
SetParamConstraint (isp_row, obj, EXPR, “ obj.isp_row “, TRUE);
NoVectorSelect = 1;
// This block is realized when joining the flange to the pipe
// The first request for a check type and subtype
if (rPart 0 & & obj.strTheType “ Tube “ & & obj.strTheSubType == “ Round “) {
// Is the nearest plane
// Set geometric
SetGeomConstraint (INSERT, CONTRDIRECT, obj, WP2, strNearestPlane, 0, TRUE);
SetGeomConstraint (DIRECITON, CODIRECT, obj, WPnormal, obj.WPnormal, 0, TRUE);
NoVectorSelect = 1;
// And parametric dependence
SetParamConstraint (Dn, obj, EXPR, “ obj.B “, TRUE);
