Conversion options
The “Conversion options” dialog is a filter that influences the set of transmitted data. Appears when converting a report to data and when exporting a table to Excel.
Converting a report to data
Delete hidden rows and columns – affects the conversion of hidden strings. If enabled, hidden rows are not passed to the data.
Turned on no hidden lines
Note:
The converted hidden lines remain hidden.
Save report template – affects the conversion of report template strings to data. If enabled, strings are transferred.
Table
Turned on
Turned off
Export to Excel
Delete hidden rows and columns – the option does not affect the result, since hidden rows are not exported.
Save report template – affects the export of report template strings. If enabled, strings are transferred.
Table
Turned off
