Fragment Copy
Main menu: Construction – Utilities > Fragment copy.
Ribbon: Construction – Utilities > Fragment copy.
Toolbar: Fragment copy (on toolbar “Utilities”).
Command line: SPCOPY.
The command is used to create remote views of the drawing.
Select the drawing center point for the detail view.
Select the area of the drawing. In the context menu, you can choose a certain kind of marquee – circle or rounded rectangle. Secure selection click.
Specify the drawing center remote fragment. available in the context menu command “0-cut” to remove the original objects from the drawing.
