Insert Underlay
Insert DWF, DWFX or PDF underlays to the drawing.
| Name: | List of inserted underlays’ names. |
Open Select Underlay file dialog to select and insert new underlay. |
| Path type: | Information about path of underlay file. Variants:
Insertion point
| Specify on-screen | Select the insertion point after the dialog box is closed. |
| X: Y: Z: | Specify the point coordinates for the underlay insertion. |
Scale
| Specify on-screen | Specify the scale of underlay after the dialog box is closed. |
| W | Width scale factor. |
| H | Height scale factor. |
| Uniform scale | Specifies the scale factor for the Width or Height values. A value specified for Width is also reflected in the Height value. |
Rotation
| Specify on-screen | Specify the rotation angle for the inserted underlay, using the pointing device. |
| Angle: | Set the rotation angle for the inserted underlay. |
Insert image relative to
| UCS | Set the insert underlay mode relative to the User Coordinate System (UCS). |
| View | Sets the insert underlay mode relative to the World Coordinate System (WCS). |
| Auto zoom | Switches on/off the full screen mode of the inserted underlay. |
Pages
Show/hide underlay page information (type, size, layer). |
Zoom and pan buttons in preview dialog. |
| Selected | Numbers of selected pages to insert. |
Buttons for transition between pages in underlay. |
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD freeware tool for Windows, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
