Parameter Properties
Not used
All parameters specified in the table, are automatically available for operations over them from the program during the insert or edit the object. If a variable is used only in the process of creating a graphic image, then use it in the script is not necessary.
Protected (used internally)
If necessary, display the parameter dialog during insertion.
Public (visible)
Used to transfer parameters during insertion and editing of other objects.
Changeable (available for editing)
Available to change other objects in the editing process. Variable of the property, will pick up from the table and the necessary parameters on the basis of the obtained values to reconstruct the details of the model.
