Saving Document
Documents can be saved in the **.dwg* drawing format, in the **.dxf* graphic data exchange format and in the **.dwt* template format. Save, Save As and WBLOCK commands are used.
Saving of an existing document
The command saves a document with its name.
Saving a new document
The Save command opens the Save Document File dialog box, where you can specify a path for a document and change the default file name:
NOTE: Navigation pane in nanoCAD list displays only those folders that are specified in Common files location section of the Options dialog:
To save a document:
- Specify the path to the file in the Folder drop-down list;
- Type the name in the File name field;
- Select the format in the File type field;
- Select the Save button.
Saving the file will be done without specifying the path and file name in the future.
NOTE: Format, specified in the File type field, is also used as default to save all documents with Save, Save As and WBLOCK commands.
Info: NanoCAD is a user friendly, cheap, and yet professional, CAD freeware tool for Windows, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool ensures innovative, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
