Create port
Main menu: Construction – Communications > Create port.
Toolbar: Communications > Create port.
Command line: SPCREATEPORT.
This command creates a new template port and places it in Template library.
To create
1. Select command
2. Show on drawing a new graphics for the port. Confirm your selection (press Enter). If the graphics is not selected, the grafics will be taken by default.
3. Specify the base point of insertion port created.
4. After specifying the form will be “Create element”, in which said storage elements in the base template, name, note and confirm the entered parameters.
5. Next, open the edit form, this form Template library. The process of editing the template “Port” is described in detail in the section Template library.
