Aligning UCS to an Object
The command specifies the new position of the coordinate system origin for the current UCS; the direction of the axes is specified according to the geometry of the current object. The extrusion direction of the selected object specifies the positive direction of the Z axis for the new UCS.
Rules to create UCS, aligned to an object:
| _.Line | |
The origin of the new UCS is set at the line end which is closest to the selection point. The X axis is used to place the line in the XZ plane. The Y coordinate of the second end of the line is zero in the new UCS. |
| Arc | |
The origin of the new UCS is the center of the arc. The X axis is set at the end of the arc which is closest to the selection point. |
| Circle | |
The origin of the new UCS is the center of the circle. The X axis is set at the selection point. |
| Point | |
The origin of the new UCS is the selection point. |
| Polyline | |
The origin of the new UCS is the start point of the polyline. The X axis is set at the start point and the nearest polyline vertex. |
| Dimension | |
The origin of the new UCS is in the middle of the dimension text. The new X axis is set parallel to the X axis of the UCS used to specify the dimension. |
| Text block insertion, attribute definition |
The origin of the new UCS is the insertion point of the object and the direction of the X axis is set by the angle of object rotation around the direction of extrusion. The object used to set the new UCS has a zero-rotation angle in this UCS. |
Command prompt:
| _.Select object to align UCS: | Select an object. |
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD program for PC, that provides a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our tool ensures creative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
