new 14
Description:
Several switches are associated with the same variable script. Each of them set any value. Variable is set to the included switch. Value is of type string. If set to “-1” value is assigned automatically starting with 1, in the tab order for TAB. In this case, the value type is numeric. Switches associated with a single variable group are considered. In the group may be included in only one switch. If a variable is assigned, grouped switches located inside one of the control. Usually this group or panel.
Properties command:
View
Visible
Tip
Linking (None)
enabled
Text Switch
Basic
Included
Value -1
Name radiobutton
Class Switch
Variable
Position
Upper limit 24
Height 24
left boundary 8
Lower limit 48
Right boundary 112
Width 104
Developments
by pressing
Example of using.
Switches allow you to choose between discrete values, the result is displayed in the input field
