Create clip boundary by two opposite points of rectangle. Boundary is perpendicular to the view plane. Its sides are orthogonal to sides of the viewport. The cloud is clipped perpendicular to the plane of the viewport in the view direction.
A cloud can be clipped in one viewport (source), with the result displayed in another viewport (target), specified by the user. When the clip result is displayed in the target viewport, the same view will be set that was in the original viewport during clipping operation.
| Enter first point: | Specify the first diagonal point of clip boundary. |
| Enter opposite corner: | Specify the second diagonal point of clip boundary. |
| Select view: | Specify needed view to display the clip. This request is displayed if there are several viewports in the model space. |
Command clip only mapping of point cloud in the target view, the object cloud itself remains unchanged. The cloud remains unchanged in the rest of viewports.
Info: NanoCAD is a simple, low cost, and yet powerful, CAD freeware tool for PC, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program supports progressive, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
