The command recalculates geocoordinates of topoplan objects to another system using EPSG codes.
To recalculate coordinates:
1. Run the command.
2. In the dialog box that appears, in the Source EPSG and Target EPSG fields, enter the number of the source and target coordinate systems according to the EPGS classification, based on the list on the left side of the window. You can use the search filter. When finished, click Apply.
3. Information about the transformation will appear at the bottom of the dialog box. Click OK to confirm the transformation.
