Table recognition
Table recognition enables automatic search and replace tables created from individual primitives nanoCAD object “Table” nanoCAD Construction . Sources are primitives for drawing.
Use the command table recognition.
Specify the drawing point at the table.
The table is created in the current layer. Dimensions of the recognized table are rounded to integer values.
Text belongs to the workpiece table is recognized as the values of the respective cells of the table.
Real dimensions of the original graphics are multiplied by the scale design, so if it turns out the table with zero height lines, you need to change the scale clearance in accordance with the size of the original graphics.
