Offset of a 3D-Polyline
The command draws a 3D polyline similar to the selected one at a specified distance from the original one, with an offset in the XY plane of the current UCS.
| Select mode [Delete/Keep]: | Set the distance by entering a value from the keyboard or by pointing on the screen. |
| Select 3dPolyline or: | Select a 3D polyline for which you want to draw a similar one. |
| Specify the offset direction: | Specify the offset direction and approximate offset distance. |
| Offset distance: | Enter exact offset distance |
