Circular construction axis
Main menu: Construction – Coordinate axes – Separate Circular Construction Axis.
Ribbon: Construction – Architecture – Separate Circular Construction Axis.
Toolbar: Separate Circular Construction Axis ( “Coordinate axes”).
Command line: SPCIRCCLINE.
To create a separate rotary axis:
Specify center point of the axis.
Specify the radius of the arc.
Specify marker angle.
Context menu of the rotary axis is as follows:
Column Marker name contains a list of the names of the markers. To add a new marker, click in an empty field and enter the name of the marker.
Arc axis
  • Hide marker – hides the marker and is only displayed in the drawing axis;
  • Hide axis – the axis hides, showing only the marker;
