Calculation of parameters
Set parameter in the dialogue
Variable for which this flag is set to be available for editing of dialogue insert details.
Dynamic selection
Processed when the position of the cursor relative to the insertion point of the object according to the formulas in the designated parameter value in the range of “minimum value” – “Maximum”.
Calculate after dialouge is shown using dynamic selection by expression
Calculated after the call dialogue and visual selection as expression in the Parameter Value.
Dont calculate parameter
Defines the minimum value. Can be expressed as a function of other parameters. Determination of the value of the parameter as a function of the cursor or other parameters. Available functions may be called from the context menu or manually entered into the appropriate input box.
Minimum value
Context menu is available in the input field.
Maximum
Defines the maximum value. Can be expressed as a function of other parameters. Context m
