Distant Light
Creates the distant light source simulating light from the sun or other far objects.
This source has no visual display in the work space, therefore it is convenient to select it from the Drawing Manager functional panel, with further editing of properties on the Properties panel.
| Set the light direction FROM: | Define the first point for setting direction of the light flux. |
| Set the light direction TO: | Define the second point for setting direction in which the light flux will go. |
| Enter the name of the modified mode or [Name/Intensity/Status/Photometry/Color/Exit]: | Define the command options, if necessary, otherwise just press Enter. |
| Name | Name of the light source. |
| Intensity | Brightness of the light: from 0 to the maximum value supported. By default, is equal to 1. |
| Status | Status of the light source: turned on/off. The disabled light source stops lighting. |
| Photometry | Photometry is the measurement of the luminous intensities of visible light sources.
| Color | Color of light given by this source.
| Exit | Exits the command. |
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD program for Windows, that allows an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software supports creative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
