Import IFC plans
The command allows you to import a plan of an architectural object from an IFC file. Plans are formed from objects nanoCAD Construction .
Important!
Before importing, make sure that you have the database of elements connected, as it contains objects nanoCAD Construction .
1. Call command
2. In the browser, select the IFC file from which the import will be made.
3. Wait a while while the plans are imported. The larger the file, the longer the import will take.
4. Plans will be built on the drawing. They will include: Formats, axes, walls, windows, doors and other architectural objects nanoCAD Construction .
