Delete edge
Using the command, you can delete edges of Submesh or Polyface mesh surface. Usually, it is used to delete “long” edges along the mesh boundary for correct contouring.
NOTE: Since a TIN surface has triangle faces, deletion of edges will result in deletion of faces that contained them.
To delete an edge:
- Run the command.
- In response to the prompt in the command line, click the edge to be deleted:
Specify edge to delete or [?]
Faces that will be deleted when deleting edges
The command is also used to delete faces inside water reservoirs to exclude the construction of contours along the reservoir.
Faces passing along the water surface
- Several edges can be deleted in succession. Pressing ESC button ends the command.
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD program for PC, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our tool provides innovative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
