Apply changes? Yes – conversion will be performed with the current settings.
or [Yes/No]: No – if the settings have been changed, they will not be preserved. Conversion will be performed with the settings that displayed right after the command started.
| Split meshes by topology | A method of exploding a mesh into smaller meshes: · Yes – split a mesh into parts taking into account both topology (Maximum difference of normals in mesh option), and limitations (no more than 500000 faces). · No – split only on the basis of limitations (no more than 500000 faces). |
| Maximum difference of normals in mesh (degrees) | The maximum allowable deviation of the normal of a mesh element from its average normal (in degrees), at which the element will be considered to belong to this mesh. The normals of elements in each part, into which a single mesh will be split, should not differ by more than a given value. The option determines the number of pieces into which the mesh will be split, if the Split meshes by topology option is set to Yes. |
| Vertex tolerance | Accuracy parameter within which closely located nodes (vertices) of objects will be combined during conversion. For example, the vertices of neighboring faces may not match within 1e-0.4, but with the Vertex tolerance value equal to 1e-0.2 such vertices will be merged into one. |
Info: NanoCAD is a simple, inexpensive, and yet professional, CAD application for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our tool ensures progressive, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
