Ribbon: Topoplan – Create TIN > Convert a Mesh, a Polyface Mesh and 3D Faces into a TIN Surface
Menu: Topoplan – Create TIN > Convert a Mesh, a Polyface Mesh and 3D Faces into a TIN Surface
Toolbar: Create TIN > Convert a Mesh, a Polyface Mesh and 3D Faces into a TIN Surface
Command line: NG_CONVERT_TO_SURFACETIN
The command converts objects of Mesh, Polyface Mesh and 3D Faces into a TIN Surface object.*
Command prompt:
Select objects or [?] Select one or more objects to convert.
The command options are specified in the Properties bar.
Delete source object Possibility to choose whether or not to delete the source objects.
