Using gestures for shortcuts
Gestures are designed for quick access to commands from the main menu of the table editor. Gestures made with pressed RMB in the table editor.
Note:
If when the prompt appears gesture command being executed, you can omit the RMB.
Right – Calculator
Left – Notebook
Up – Expression
Down – Cell properties
Right hook – Return
Left hook – Cancel
The closed area of the selected cells in a clockwise direction – Connection (merged cells pre-allocated)
Result:
The closed area of the selected cells counterclockwise – Disconnection
Result:
Symbol “z” on select cells – Clear (pre-clean cell is released)
Result:
