Hatch contour
Important!
The command prepares the sketch for recognizing the execution type of the base object.
A hatch contour defines the shaded area of an object in the drawing.
1. Draw a closed polyline in the sketch that matches the shape and size of the required hatch contour (in the figure, a rectangle around the sketch).
2. Call the command
3. Select the constructed polyline. The outline will be highlighted in red in the sketch.
A prerequisite for the contour is the absence of self-intersections. To avoid self-intersections on a compound contour, create the contour manually, leaving a minimum “isthmus” between the areas.
Wrong Right
