In nanoCAD there is a mechanism for embedding of raster images. Inserted images saved in external raster files can be embedded and saved in drawing file.
To embed the raster:
1. Open dialog External References (menu Insert – External References).
2. Select reference to a raster image.
3. Click the
Embedded image has no saved path, and type of reference becomes Embedded.
ATTENTION! Embedded raster images increase the file size greatly.
Using !https://manula.r.sizr.io/large/user/13178/img/sf.png!* Save file* dialog command and assigning saved path you can make the image inserted as reference again.
