Copy objects to new layer
Creation of selected objects copies on the specified layer. For objects’ copies you can specify another location. It is possible to select objects beforehand.
| Name | Starts the Copy to Layer dialog to specify a layer where objects’ copies are placed. |
| Displacement | A value of displacement of objects’ copies by specifying a relative distance by entering coordinates. Coordinates specify a displacement value of objects’ copies not a point location. |
| Exit | Finishes the command without objects’ replacement. |
Command prompts when specifying a base point
| Select an object to change its layer or [?]: | Select objects. |
| Select object on destination layer or [?/Name]: | Select an object on a layer to place copies. |
| Select object on destination layer or [?/Name]: | Select Name option to specify a layer in the Copy to Layer dialog. |
| Specify base point or [Displacement/Exit] | Specify a base point to replace the copied objects. |
| Specify second point or displacement | Specify a second point for replacement. |
Command prompts when you replace copies:
| Specify base point or [Displacement/Exit] | Select Displacement. |
| Specify displacement: | Enter coordinates values, which specify relative distance and direction. |
Info: NanoCAD is a simple, cheap, and yet professional, CAD app for Windows, that delivers an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
