Mechanica Utilities
Creating a hatch
CAD drafting UTILITIES 0Main menu: Mechanical – Utilities – CAD software UTILITIES 1Create hatch.
CAD drawing UTILITIES 2Toolbar: Utilities – CAD drafting UTILITIES 3Create hatch.
CAD software UTILITIES 4Command line: MCHPATTERN.
In nanoCAD Mechanica 23 it is possible to create hatches according to a given pattern – a sketch using the CAD drawing UTILITIES 5“Create hatch” tool. The hatch pattern created with it is written as an independent * .pat file and can be used in other projects or by other users.
1.Create a border for the hatch sketch. Construct a 300×300mm rectangle and place its bottom-left corner at the origin of coordinate system 0,0,0. The sketch area must be at the origin of the coordinate system. Overall dimensions of the sketch area should not be more than 300×300mm.
CAD drafting UTILITIES 6
2. Sketch one element of the future hatch. The sketch needs to be done within the created rectangle. The sketch should only be done with lines. It is not allowed to sketch with arcs, circles. It is recommended to approximate curved objects in polylines without arc segments. Sketch polylines must be exploded into line segments.
CAD software UTILITIES 7
3. Assign a different color to each section of the sketch. The sketch should be done with segments of different colors. The hatch tool recognizes the periodicity in the sketch by the color of the lines.
CAD drawing UTILITIES 8
4. Create an array of sketches within a rectangle. The sketch must follow an explicit periodicity. The sketch must include at least three repeating fragments of the future hatching.
CAD drafting UTILITIES 9
5. Call the command CAD software UTILITIES 10“Create hatch”.
6. Create an array of sketches within a rectangle. The sketch must follow an explicit periodicity. The sketch must include at least three repeating fragments of the future hatching.
CAD drawing UTILITIES 11
7. Press the “Enter” key. The process of object recognition and analysis will begin. During recognition, gaps in sketch lines are automatically determined, if in the selected pattern the line break is outside the selection boundary, the line will be defined in the hatch as continuous. If the sketch does not meet the conditions, a message box will appear, otherwise the file save dialog.
8. Correct the errors indicated in the message. Repeat step 5 – step 7.
9. In the file save dialog specify the path to the hatch file.
Important!
You cannot use the names “Acad.pat”, “Acadiso.pat” as the name of the sample file. It is recommended to save in C:\ProgramData\Nanosoft\nanoCAD Mechanica 23\SHX
10. The custom hatch will be created. The hatch created with the CAD drafting UTILITIES 12“Create hatch” tool fully accepts all the properties of the nanoCAD hatch: associativity, the ability to change the scale, the angle of inclination, overlay with a closed tolerance.
Important!
A drawing file * .dwg that used a unique hatch must be transferred to another user along with the * .pat file of the hatch pattern. For a successful translation, use the (eTransmit) “Generate Set” command.
Objects numeration
CAD software UTILITIES 13Main menu: Mechanical – Utilities – CAD drawing UTILITIES 14Objects numeration.
CAD drafting UTILITIES 15Ribbon: Mechanical – Utilities – CAD software UTILITIES 16Objects numeration.
CAD drawing UTILITIES 17Toolbar: CAD drafting UTILITIES 18Objects numeration (on toolbar “MCS Utilities”).
CAD software UTILITIES 19Command line: MCNUMOBJ.
The command finds all specified objects with attributes and numbers it according to a given algorithm.
1. Call the team. The “Object Numbering” dialog opens.CAD drawing UTILITIES 20
2. Select objects. Select an object using the quick selection. All objects that have text editable attributes (block, database object, universal marker, etc.) can be selected.CAD drafting UTILITIES 21
After selecting an object, a list of attributes common to the selected objects and available for editing is formed.
Additional list management commands:
CAD software UTILITIES 22Set selection – the command allows you to specify objects in the drawing.
CAD drawing UTILITIES 23Reset conditions – command clears the list of conditions.
3. Select the attribute in which the result of numbering will be recorded.CAD drafting UTILITIES 24
4. Select the numbering method:CAD software UTILITIES 25- from left to rigth, from top to bottom. When choosing this method, the command compares the coordinates of points X and Y, respectively, starts numbering from the highest and leftmost objects to the lowest and right relative to the base point.
CAD drawing UTILITIES 26- from bottom to top, from left to right. When choosing this method, the command compares the coordinates of points X and Y, respectively, starts numbering from the lowest and leftmost of the entire object to the highest and right relative to the base point.
CAD drafting UTILITIES 27- from rigth to left, from top to bottom. When choosing this method, the team compares the coordinates of points X and Y, respectively, starts numbering from the topmost and to the right of the entire object to the lowest and leftmost relative to the base point.
CAD software UTILITIES 28- from bottom to top, from right to left. When choosing this method, the command compares the coordinates of points X and Y, respectively, starts numbering from the lowest and most right of the entire object to the highest and left relative to the base point.
CAD drawing UTILITIES 29- radial anticlockwise. When choosing this method, the command compares the coordinates of points in the polar coordinate system, the distance from the center (specified by the user base point) and the angle between the zero direction (positive X-axis direction). Numbering is counterclockwise. When this method is selected, the selection of the base point becomes available.
CAD drafting UTILITIES 30- radial clockwise. When choosing this method, the command compares the coordinates of points in the polar coordinate system, the distance from the center (specified by the user base point) and the angle between the zero direction (positive X-axis direction). Priority in comparison has an angle. Numbering is clockwise. When this method is selected, the selection of the base point becomes available.
CAD software UTILITIES 31- spiral anticlockwise from center. When choosing this method, the command compares the coordinates of points in the polar coordinate system, the distance from the center (specified by the user base point) and the angle between the zero direction (positive X-axis direction). Priority when comparing has distance from the center. The numbering is counterclockwise from the center. When this method is selected, the selection of the base point becomes available.
CAD drawing UTILITIES 32- spiral clockwise to center. When choosing this method, the command compares the coordinates of points in the polar coordinate system, the distance from the center (specified by the user base point) and the angle between the zero direction (positive X-axis direction). Priority when comparing has distance from the center. Numbering is clockwise to the center. When this method is selected, the selection of the base point becomes available.
5. Indicate a base point if necessary. The base point is indicated either by entering the X and Y coordinates, or by pointing to the screen. When cocking the “Specify point” checkbox, the point is indicated after pressing the “OK” button.CAD drafting UTILITIES 33
6. Customize the brand. The formation of the brand comes from three parts. The prefix and suffix is specified in the editable field. And the brand value itself is calculated based on the initial value entered by the user and the step between subsequent values.CAD software UTILITIES 34
7. Click “OK.” 8. If the “Specify point” checkbox has been set, specify the base point in the drawing. 9. Numbering will be made.Measurements
CAD drawing UTILITIES 35Main menu: Mechanical – Utilities – CAD drafting UTILITIES 36Measure.
CAD software UTILITIES 37Ribbon: Mechanical – Design – CAD drawing UTILITIES 38Measure.
CAD drafting UTILITIES 39Toolbar: CAD software UTILITIES 40Measure (on toolbar “Utilities”).
CAD drawing UTILITIES 41Command line: MCMEASURE.
Measurements or tool with Mark drawing is designed to extract various properties of objects in the drawing.
After selecting the command a dialog box value picker opens.
CAD drafting UTILITIES 42
CAD software UTILITIES 43Measure distance. Measures the distance between two points, radius or diameter. Switching the measurement method is via the context menu.
CAD drawing UTILITIES 44Measure angle. Measures the angle.
CAD drafting UTILITIES 45Measure Perimeter. Measure the perimeter of the closed area, the length of a closed polyline or circle.
CAD software UTILITIES 46Measure area. Measures the area of the closed area. Select an area in two ways: 1 – Click inside the closed loop, 2 – Click on the closed polyline or circle.
CAD drawing UTILITIES 47Complex area. Measures the area of several loops. Selecting the area is carried out: 1 – Click to specify the first closed loop, 2 – Click to specify the second closed loop 3 – Press Enter to complete the command.
CAD drafting UTILITIES 48Take from property. Allows you to get the value of the parameter selected in the drawing object nanoCAD Mechanica23.
CAD software UTILITIES 49
CAD drawing UTILITIES 50Take from text. Returns the value of the selected single-line or multi-line text.
CAD drafting UTILITIES 51Calculate. Opens calculator.
CAD software UTILITIES 52Take from notes. Opens the notebook.
The measured values are displayed in the dialog box.
If universal measuring time was part of a command (for example, the dialog box nanoCAD Mechanica23 text context menu command), the measured value is transmitted to the command being executed.
Fragment Copy
CAD drawing UTILITIES 53Main menu: Mechanical – Utilities – CAD drafting UTILITIES 54Fragment copy.
CAD software UTILITIES 55Ribbon: Mechanical – Utilities – CAD drawing UTILITIES 56Fragment copy.
CAD drafting UTILITIES 57Toolbar: CAD software UTILITIES 58Fragment copy (on toolbar “Utilities”).
CAD drawing UTILITIES 59Command line: MCCOPY.
The command is used to create remote views of the drawing.
1. Select the drawing center point for the detail view. 2. Select the area of the drawing. In the context menu, you can choose a certain kind of marquee – circle or rounded rectangle. Secure selection click. 3. Specify the drawing center remote fragment. available in the context menu command “0-cut” to remove the original objects from the drawing.Plate Array
CAD drafting UTILITIES 60Main menu: Mechanical – Utilities – CAD software UTILITIES 61Plate array.
CAD drawing UTILITIES 62Ribbon: Mechanical – Utilities – CAD drafting UTILITIES 63Plate array.
CAD software UTILITIES 64Toolbar: CAD drawing UTILITIES 65Plate array (on toolbar “Utilities”).
CAD drafting UTILITIES 66Command line: MCPLTARRAY.
Command to tile layouts for a given circuit.
1. Choose from a base tile pattern and place it on the drawing.CAD software UTILITIES 67
2. Press the CAD drawing UTILITIES 68plate array. 3. In the opened window, click the plate shema and specify the token group.CAD drafting UTILITIES 69
4. Select Trim mode extreme tiles . · Trim plates by area border – tiles clipped to the boundary of the layout. Circuit tile becomes open. This tile is taken into account in property “Cut”. This mode is not available if you enable the check box “Make each tile a separate.” · Include trimmed plates – extreme tiles stacked atop circuit layout. · Exclude trimmed plates – tiles, overlapping circuit layouts do not fit. · Sect border type face- if tiles have execution end elements will be selected most podhodyaeschee. When the layout of the area selected by the execution system names: Whole, Left, Right, Top, Bottom. When the layout along the border all versions checked sequentially, regardless of names.Trim plates by area border
CAD software UTILITIES 70
CAD drawing UTILITIES 71
CAD drafting UTILITIES 72
CAD software UTILITIES 73
5. Create each plate as a separate object.If the box is checked, the result will be a group of independent layout objects – copies of the original objects. This mode does not support cutting elements on the boundaries of the area, but allows more flexibility to edit the result.
When the check box is created off a single object that includes all geometry. In the properties of this object will be information on the number, weight and costs of each type of tiles, as well as the total weight (based on the whole tiles) and cost. You can delete individual tiles by clicking on them with the right. In this case the total amount will be adjusted, weight and cost.
6. Determine the work area tiles. · auto detect – layout area defined contour, which is located inside the tile pattern. In the inner islands stacked tiles will not. · magnet – loop selection tool “magnet”. · select – area layout is selected in the drawing indicating one or more loops. · border – tiles splits along the perimeter or primitives nanoCAD. Cropping mode in this case will simulate laying curbs. 7. To complete the command, press OK.Note:
Creating a template tile layouts can be done using Object Wizard.
Creating an array of objects
CAD drawing UTILITIES 74Main menu: Mechanical – Utilities – CAD drafting UTILITIES 75Array.
CAD software UTILITIES 76Ribbon: Mechanical – Utilities – CAD drawing UTILITIES 77Array.
CAD drafting UTILITIES 78Toolbar: CAD software UTILITIES 79Array (on toolbar “Utilities”).
CAD drawing UTILITIES 80Command line: MCARRAY.
Replication called ordered distribution of copies of objects by step and quantity. Duplication of graphics in the nanoCAD Mechanica23 is performed using a dialog box arrays.
Four tabs in the Arrays dialog box define four (4) different object replications.
· Arrays along an arbitrary path · Arrays for arc trajectory · Rectangular array · An array of stepFor the distribution of objects within a specified area used for an array field .
1. Tab Path enter the governing parameters. 2. Follow The selection object (object selection). 3. Specify the base point. 4. Select trajectory. 5. Follow View . 6. Click OK to complete the command.CAD drafting UTILITIES 81
At the top of the window is a group of controls placement, which allows you to select:
· Quantity; · Copy step; · Base point; · Step correction;In the drop-down list make a choice of Overlap:
· Transparent objects; · Next under preceding; · Next Over preceding; · Interleave.Button CAD software UTILITIES 82 pick from drawing step allows you to select copies of the objects in the drawing.
Switch Show hidden line controls the display of hidden lines in the drawing. If the switch is on the hidden lines are displayed in the drawing.
Switch Rotate copies controls the orientation of the copied object. If the switch is on when copying objects are rotated so that the vector Y was directed perpendicularly to the path (as shown in the figure).
Button CAD drawing UTILITIES 83 Selection to select the replication object in the drawing.
Button CAD drafting UTILITIES 84 from the base to select the object from the database replication of standard elements.
Button Base point lets you choose the base point of duplicated object (normally it should be expressed in the center or corner of the object).
Button select a trajectory to select a graphic object, along which you will be replicating. As the trajectory can be used lines, polylines, arcs, circles.
CAD software UTILITIES 85
1. Tab Arc enter the governing parameters. 2. Follow The selection object (object selection). 3. Select Center array. 4. Follow Preview . 5. Click OK to complete the command.CAD drawing UTILITIES 86
At the top of the window is a control group accommodation, which lets you choose placing of replicated objects:
· By number and step; · By number and angle; · By step and corner;In the input field Number specify the number of replicated objects.
In the entry field Step Angle enter the angle between the replicable elements.
In the input field angle specify the angle required.
Button CAD drafting UTILITIES 87with Mark drawing step allows you to select the corner or angle with the drawing.
· Transparent objects; · Next under preceding; · Next over preceding; · Interleave.Switch Show hidden line controls the display of hidden lines in the drawing. If the switch is on the hidden lines are displayed in the drawing.
Button CAD software UTILITIES 88 Selection to select the replication object in the drawing.
Button CAD drawing UTILITIES 89 insert from database used for selecting a center point which the objects will be replicated.
Button array center used for selecting a center point which the objects will be replicated.
Switch Rotate copies controls the orientation of the copied object. If the switch is on the turn when copying objects are shown in the figure.
CAD drafting UTILITIES 90
Rectangular array
1. Command Rectangle enter key parameters. 2. Follow The selection object (object selection). 3. Follow Preview . 4. Click OK to complete the command.CAD software UTILITIES 91
Enter the number of objects in the array horizontally and vertically, to specify the amount of horizontal and vertical steps between objects.
Steps of an array
1. Tab steps enter the governing parameters. 2. Follow The selection object (object selection). 3. Follow > View . 4. Click OK to complete the command.CAD drawing UTILITIES 92
Enter the number of objects in the array, specify the amount of horizontal and vertical step between objects.
CAD drafting UTILITIES 93
Area array
CAD software UTILITIES 94Main menu: Mechanical – Utilities – CAD drawing UTILITIES 95Area array.
CAD drafting UTILITIES 96Ribbon: Mechanical – Utilities – CAD software UTILITIES 97Area array.
CAD drawing UTILITIES 98Toolbar: Utilities – CAD drafting UTILITIES 99Area array.
CAD software UTILITIES 100Command line: MCARDARRAY.
The tool is designed to replicate objects within a given area.
1. Call the command CAD drawing UTILITIES 101“Area array”. A dialogue will open “Area array”.
CAD drafting UTILITIES 102
2. Click the “Object(s)” button and select the original objects to copy in the drawing. Press the “Enter” key to complete the selection.
3. Select the method of placing the copied objects using the graphic switch:
CAD software UTILITIES 103 – Rhombus.
CAD drawing UTILITIES 104 – Square.
CAD drafting UTILITIES 105 – Triangle.
4. Specify the spacing (H) between adjacent copies. The CAD software UTILITIES 106“Pick from drawing” button allows you to select a step from the drawing.
5. Specify the minimum indent (?) from the edge of the area. The CAD drawing UTILITIES 107“Pick from drawing” button allows you to select an indent from the drawing.
6. Set the area of the array in one of three ways:
· CAD drafting UTILITIES 108“Select an area by the point”. The construction area is formed from a set of closed areas. The command allows you to add closed areas to the set by clicking the LMB inside a closed contour in the drawing. Clicking again inside the contour removes the selected area from the set. To complete the selection, press the “Enter” key. · CAD software UTILITIES 109“Select contour with the magnet”. The contour of the array area is set using the utility “Magnet”. · CAD drawing UTILITIES 110“Paint area”. The command allows you to specify an arbitrary placement of copied objects, providing a set step between adjacent copies. This command is available only after selecting the source objects to copy.The construction of the area is carried out by moving the mouse cursor over the drawing (construction must be started from the location of the original objects). As you move the cursor, markers will appear on the screen to indicate where the copied objects are inserted.
CAD drafting UTILITIES 111
To remove insertion markers, press and hold the “Shift” key. When you hover over a marker, the marker will be deleted.
To temporarily disable the placement of markers, press and hold the “Ctrl” key.
Finish drawing the area by clicking LMB. An array by area will be built.
7. Click the “OK” button. An array by area will be built.
Centerlines
CAD software UTILITIES 112Main menu: Mechanical – Utilities – CAD drawing UTILITIES 113Centerlines.
CAD drafting UTILITIES 114Ribbon: Mechanical – Utilities – CAD software UTILITIES 115Centerlines.
CAD drawing UTILITIES 116Toolbar: Utilities – CAD drafting UTILITIES 117Centerlines.
CAD software UTILITIES 118Command line: MCAXIS.
The command is designed to draw centerlines.
The construction method depends on the selected objects:
· Parallel lines. The centerline will be drawn in the middle between these segments.1. Call the command CAD drawing UTILITIES 119“Centerlines”.
2. Select the first line.
3. Select the second line.
4. Specify manually the first point of the centerline or press the “Enter” key. When you press the “Enter” key, the centerline is drawn automatically with a protrusion specified in the settings (by default 2mm).
5. Specify manually the second point of the centerline or press the “Enter” key. When you press the “Enter” key, the centerline will stop drawing, the second point will be in the calculated center between the lines.
In the case of manual selection of the start / end point of the centerline, the amount of the protrusion is controlled by the user.
CAD drafting UTILITIES 120
· Non-parallel line segments. The centerline will be drawn along the bisector of the angle between the line segments.1. Call the command CAD software UTILITIES 121“Centerlines”.
4. Select the direction of the centerline. Using the “Rotate” context menu command, you change the direction of the centerline drawing (available only for intersecting line segments).
5. Specify manually the first point of the centerline or press the “Enter” key. When you press the “Enter” key, the centerline is drawn automatically with a protrusion specified in the settings (by default 2mm).
6. Specify manually the second point of the centerline or press the “Enter” key. When you press the “Enter” key, the centerline will stop drawing, the second point will be in the calculated center between the lines.
CAD drawing UTILITIES 122
· One circle. Draws centerline centerlines on the selected circle.1. Call the command CAD drafting UTILITIES 123“Centerlines”.
2. Pick a circle.
3. Press the “Enter” key.
CAD software UTILITIES 124
· Two or more circles. Draws centerline centerlines on selected circles with one common centerline.1. Call the command CAD drawing UTILITIES 125“Centerlines”.
2. Select the first circle.
3. Select the second circle.
4. Press the “Enter” key. If on the line between the centers of the two selected circles there are also centers of other circles, then for such circles, axial ones will also be built.
CAD drafting UTILITIES 126
· Three mismatched circles. Creates a circle of centers passing through the centers of the selected circles. Center axes are automatically added to all circles whose centers coincide with the constructed center circle.1. Call the command CAD software UTILITIES 127“Centerlines”.
4. Select the third circle.
CAD drawing UTILITIES 128
Fillet
CAD drafting UTILITIES 129Main menu: Mechanical – Utilities – CAD software UTILITIES 130Fillet.
CAD drawing UTILITIES 131Ribbon: Mechanical – Utilities – CAD drafting UTILITIES 132Fillet.
CAD software UTILITIES 133Toolbar: CAD drawing UTILITIES 134Fillet (on toolbar “Utilities”).
CAD drafting UTILITIES 135Command line: MCFILLET.
Command Options
CAD software UTILITIES 136
CAD drawing UTILITIES 137Pick from drawing
CAD drafting UTILITIES 138 Mode full trim contour lines
CAD software UTILITIES 139 Mode partial trim lines to their intersection
CAD drawing UTILITIES 140 Mode without cutting
CAD drafting UTILITIES 141Copying properties
CAD software UTILITIES 142 Measure fillet. Tabulated fillet radius and the number
CAD drawing UTILITIES 143 Extra measurement. Stamped dimensions of the original geometry. Active only when the button “dimensioned pairing”
CAD drafting UTILITIES 144
CAD software UTILITIES 145Insert circle as fillet.
Double click the left mouse button or click the right mouse button in the input fields of values, a context menu will open with a list of the last entry:
CAD drawing UTILITIES 146
When a command from the context menu, the following options::
CAD drafting UTILITIES 147
properties – Open the dialogue to change the chamfer .
new – Completion of a group of facets and the beginning of another. This command is used when you need to, for example, several facets of the same size on the same site, and then with the same dimensions – on the other:
Chamfer – Switch to build Circle. After you select the shortcut menu command opens this dialog Pairing parameter setting interface.
polyline – Switching to chamfering along the selected polyline. This option is available if you have selected the type of symmetric Circle: one length or two identical length. In operation, the cut-off modes are ignored and dimensioning.
Features of the Command
Command works in 3D. To execute the command source primitives must lie in one plane
If you select the second object, press and hold SHIFT, then the angle will be formed (at the intersection of the closure and isolation).
CAD software UTILITIES 148CAD drawing UTILITIES 149
For a pair of ARC-ARC additionally available pairing, combining internal and external touch.
CAD drafting UTILITIES 150CAD software UTILITIES 151
CAD drawing UTILITIES 152
Availability of different types of interfaces depends on the fillet radius. To the outside and combining the radii need greater magnitude than the inner.
When two parallel lines will be constructed pairing radius equal to half the distance between them (regardless of the specified length). Automatically aligns the sides to the longest segment. When two parallel lines will be constructed pairing radius equal to half the distance between them (regardless of the specified length). Automatically aligns the sides to the longest segment.
CAD drafting UTILITIES 153
Pairing works parallel segments and regions of the same polyline.
CAD software UTILITIES 154
Side interface depends on the position of the mouse cursor when the second object
When you insert a polyline retains its integrity.
If the team is formed of two polylines one, it will be object of a single polyline.
If you select one polyline segments separated by other sites, all the intermediate portions are removed.
CAD drawing UTILITIES 155CAD drafting UTILITIES 156
Chamfer
CAD software UTILITIES 157Main menu: Mechanical – Utilities – CAD drawing UTILITIES 158Chamfer.
CAD drafting UTILITIES 159Ribbon: Mechanical – Utilities – CAD software UTILITIES 160Chamfer.
CAD drawing UTILITIES 161Toolbar: CAD drafting UTILITIES 162Chamfer (on toolbar “Utilities”).
CAD software UTILITIES 163Command line: MCCHAMFER.
Command Options
This command is used for automatic and semi-automatic placement of face on the details with the various versions and with the possibility of automatic dimensioning.
After clicking the command, it opens a dialog box settings Circle:
CAD drawing UTILITIES 164
CAD drafting UTILITIES 165Mode chamfering parts with two different sizes
CAD software UTILITIES 166CAD drawing UTILITIES 167
CAD drafting UTILITIES 168Mode chamfering parts with two different sizes
CAD software UTILITIES 169CAD drawing UTILITIES 170
CAD drafting UTILITIES 171Mode Chamfer length and angle in this mode instead of the length 2 displays the setting angle.
CAD software UTILITIES 172CAD drawing UTILITIES 173
CAD drafting UTILITIES 174 Mode full cutting contour lines
CAD software UTILITIES 175 Mode partial cutting lines to their intersection
CAD drawing UTILITIES 176 Mode without cutting
CAD drafting UTILITIES 177 Measure Chamfer
CAD software UTILITIES 178 Copy properties surrounding face
CAD drawing UTILITIES 179 Pick from drawing
Double click the left mouse button or click the right mouse button in the input fields of values, context menu will open with a list of the last entry:
CAD drafting UTILITIES 180
CAD software UTILITIES 181
Propertise – Opening the dialogue to change the chamfer chamfer.
New – Completion of a group of facets and the beginning of another. This command is used when you need to, for example, several facets of the same size on the same site, and then with the same dimensions – on the other:
Fillet – Switch to build pairings. After you select the shortcut menu command opens this dialog Pairing parameter setting interface.
Polyline – Switching to chamfering along the selected polyline. This option is available if you have selected the type of symmetric Circle: one length or two identical length. In operation, the cut-off modes are ignored and dimensioning.
Features of the command
The command works in 3D. To execute the command source primitives must lie in one plane.
CAD drawing UTILITIES 182CAD drafting UTILITIES 183
If the team is formed of two polylines one, it will be object to a single polyline.
CAD software UTILITIES 184CAD drawing UTILITIES 185
Breaks
CAD drafting UTILITIES 186Main menu: Mechanical – Utilities – Breaks – CAD software UTILITIES 187Break lines.
CAD drawing UTILITIES 188Ribbon: Mechanical – Utilities – CAD drafting UTILITIES 189Break lines.
CAD software UTILITIES 190Toolbar: CAD drawing UTILITIES 191Break lines ( “MCSBreaks”).
CAD drafting UTILITIES 192Command line: MCBREAK.
1. Select the first point to insert the break line.
2. In the context menu, select the type of break (break) (Linear, Two-lenear, Curved, tWo-curved, tuBular).
3. Pick the second break point.
4. In the context menu, select the type of cursor movement control (FreeOffset, OrthoOffset).
5. Specify the width of the cliff (break). A cliff (break) will be built.
Note:
The whole clipped geometry between the break lines is not actually deleted and can be restored either by removing the break line or editing its contour with the grips nodal points.
Note:
All objects nanoCAD Mechanica 23 have a so-called Z-Order. This value sets the level of the Z-coordinate in relation to other object-dependent details nanoCAD Mechanica 23. Editing the value of the order, you can control the mutual overlap of objects nanoCAD Mechanica 23.
Dialogue
The edit dialog is opened from the tooltip when you hover on a break (break) or when you double-click on a break (break).
CAD software UTILITIES 193
Editing dialog includes:
· Graphic break type switch; · Field “Length”; · Field “Width”; · Field “Offset”. You can get the value using the offset command CAD drawing UTILITIES 194“Parallel to specified line”.Grips
1. Grips length setting 2. Grips break width settings 3. Break displacement grip 4. Drop-down type grip · Linear · Two-linear · Curve · Two-curve · TubularCAD drafting UTILITIES 195
Linear break
CAD software UTILITIES 196Main menu: Mechanical – Utilities – Breaks – CAD drawing UTILITIES 197Linear break.
CAD drafting UTILITIES 198Ribbon: Mechanical – Utilities – CAD software UTILITIES 199Linear break.
CAD drawing UTILITIES 200Toolbar: CAD drafting UTILITIES 201Linear break ( “MCSBreaks”).
CAD software UTILITIES 202Command line: MCBREAK_LINEAR.
Two-linear break
CAD drawing UTILITIES 203Main menu: Mechanical – Utilities – Breaks – CAD drafting UTILITIES 204Two-linear break.
CAD software UTILITIES 205Ribbon: Mechanical – Utilities – CAD drawing UTILITIES 206Two-linear break.
CAD drafting UTILITIES 207Toolbar: CAD software UTILITIES 208Two-linear break ( “MCSBreaks”).
CAD drawing UTILITIES 209Command line: MCBREAK_TWOLINEAR.
Curved break
CAD drafting UTILITIES 210Main menu: Mechanical – Utilities – Breaks – CAD software UTILITIES 211Curved break.
CAD drawing UTILITIES 212Ribbon: Mechanical – Utilities – CAD drafting UTILITIES 213Curved break.
CAD software UTILITIES 214Toolbar: CAD drawing UTILITIES 215Curved break ( “MCSBreaks”).
CAD drafting UTILITIES 216Command line: MCBREAK_CURVED.
Two-curved break
CAD software UTILITIES 217Main menu: Mechanical – Utilities – Breaks – CAD drawing UTILITIES 218Two-curved break.
CAD drafting UTILITIES 219Ribbon: Mechanical – Utilities – CAD software UTILITIES 220Two-curved break.
CAD drawing UTILITIES 221Toolbar: CAD drafting UTILITIES 222Two-curved break ( “MCSBreaks”).
CAD software UTILITIES 223Command line: MCBREAK_TWOCURVED.
Shaft break
CAD drawing UTILITIES 224Main menu: Mechanical – Utilities – Breaks – CAD drafting UTILITIES 225Shaft break.
CAD software UTILITIES 226Ribbon: Mechanical – Utilities – CAD drawing UTILITIES 227Shaft break.
CAD drafting UTILITIES 228Toolbar: CAD software UTILITIES 229Shaft break ( “MCSBreaks”).
CAD drawing UTILITIES 230Command line: MCBREAK_TUBULAR.
Construction lines
CAD drafting UTILITIES 231Main menu: Mechanical – Utilities – Construction lines.
CAD software UTILITIES 232Ribbon: Mechanical – Utilities – Construction lines.
CAD drawing UTILITIES 233Toolbar: “Construction lines”.
CAD drafting UTILITIES 234
Auxiliary lines are characterized by a layer in which they are placed by default (MCSCLines), color (red) and line type (thin solid), that are set in the settings. Additional settings – prostanovki rays or lines. Settings only apply to newly inserted objects. When you switch the existing objects remain as it is.
The table below describes which objects need to select and how formed auxiliary line in terms nanoCAD.
Some commands allow you to specify a sequence of auxiliary lines in the format XX|XX|XX, where XX – the amount of displacement of the beam (direct) in degrees or drawing units from the base position or previous beam, rendered in this command.
Command
Name
The algorithm works command
Objects of choice
When drawing rays (_ray)
When drawing lines (_xline)
CAD software UTILITIES 235Mcconsthor
Create a horizontal auxiliary line
Command is invoked _ray, in which the user is given the insertion point. The second point is determined by the program to define the orientation of the beam is strictly horizontal. Point is determined by the positive direction of the X axis.
CAD drawing UTILITIES 236
Option R-Turn-ray-to-180-degrees allows you to change the direction of the beam on the opposite
Command is invoked _xline, in which the user is given the insertion point. The second point is determined by the program to define the orientation of the line is strictly horizontal.
Insertion point
CAD drafting UTILITIES 237Mcconstver
Creating vertical reference line
Command is invoked _ray, in which the user is given the insertion point. The second point is determined by the program to define the orientation of the beam is strictly vertical. Point is determined by the positive direction of the axis Y.
CAD software UTILITIES 238
Option Rotate-ray-through-180-degrees allows you to change the direction of the beam on the reverse.
Command is invoked _xline, in which the user is given the insertion point. The second point is determined by the program to define the orientation of the line is strictly vertical.
Insertion point
CAD drawing UTILITIES 239Mcconstz
Create an auxiliary line in the direction Z
Command is invoked _ray, in which the user is given the insertion point. Constructed beam emerging from this point in the positive direction OZ.
CAD drafting UTILITIES 240
Insertion point
CAD software UTILITIES 241Mcconstcrs
Creating auxiliary lines intersecting
Command is invoked _ray, in which the user is given the insertion point. Built at the intersection of the rays of the insertion point in the positive direction of the axes OX and OY.
Options allow you to select the quadrant bounded by the rays.
Command is invoked _xline, in which the user is given the insertion point. Constructed lines intersect at the insertion point.
Insertion point
CAD drawing UTILITIES 242Mcconsthb
Create an auxiliary line by two points or corner
Command is invoked _ray,in which the user is given the insertion point. Then to complete the command inserted rays at a predetermined angle with respect to OX (angle determined by the second point specified by the user) or a number of angles for group insert format XX | XX | XX.
Command is invoked _xline, in which the user is given the insertion point. Then to complete the command inserted straight with a predetermined angle with respect to OX (angle determined by the second point specified by the user) or a number of angles for group insert format XX | XX | XX.
Insertion point, a point which determines the angle (angle) or entering a number. The command completed after entering the series or after the forced shutdown command (Esc or right button).
CAD drafting UTILITIES 243Mcconsthw
Create an auxiliary line at an angle to the segment
Command is invoked _ray, in which the user is given the insertion point. Specifies the position of the base angle (line). Then to complete the command inserted rays at a predetermined angle relative to the base angle or angles for a number of bulk-insert format XX | XX | XX. The angle is determined by the user of said second point.
Command is invoked _xline, in which the user is given the insertion point. Specifies the position of the base angle (line). Then to complete the command inserted straight with a predetermined angle relative to the base angle or angles for a number of bulk-insert format XX | XX | XX. The angle is determined by the user of said second point.
Insertion point, the point defining the base angle (or segment), which determines the point angle (angle) or entering a number. The command completed after entering the series or after the forced shutdown command (Esc or right button).
CAD software UTILITIES 244Mcconstpar
Creating an auxiliary line parallel at a predetermined distance
Command is invoked_ray, in which the user selects a segment, polyline, line or ray. Further, given the parallel position of the object as a point through which it must pass (in the case of a polyline – equidistant) or number of copies of an object in the format XX | XX | XX.
Command is invoked _xline, in which the user selects a segment, polyline, line or ray. Further, given the parallel position of the object as a point through which it must pass (in the case of a polyline – equidistant) or number of copies of an object in the format XX | XX | XX.
Beam line, polyline or line. Reference point or enter a number. The command completed after entering the series or after the forced shutdown command (Esc or right button).
CAD drawing UTILITIES 245Mcconstpar2
Creation of a parallel auxiliary line at half the specified distance
Command is invoked _ray, in which the user selects a segment, polyline, line or ray. Further, given the parallel position of the object as a point through which it must pass (in the case of a polyline – equidistant) or number of copies of an object in the format XX | XX | XX. The resulting objects are at half of the distance.
Command is invoked _xline, in which the user selects a segment, polyline, line or ray. Further, given the parallel position of the object as a point through which it must pass (in the case of a polyline – equidistant) or number of copies of an object in the format XX | XX | XX. The resulting objects are at half of the distance.
CAD drafting UTILITIES 246Mcconstlot2
Establishment of a subsidiary of the perpendicular by two points
Command is _ray, in which the user is given the insertion point. Then, the user specifies the second point (a preview is rendered beam and segment coming from the insertion point, the second point is tied to the cursor) to specify the second point forms perpendicular to the beam. Ray is drawn perpendicular to the object.
Command is invoked _xline, that sets the insertion point. Then, the user specifies the second point (a preview is rendered straight and cut coming from the insertion point, the second point is tied to the cursor) to specify the second point forms perpendicular to the line. Direct drawn perpendicular to the object.
Insertion point, reference point on the perpendicular to the object renders.
CAD software UTILITIES 247Mcconstlot
Create an auxiliary line perpendicular to the segment
Command is invoked _ray, for which the user selected reference object and point to it. Ray is drawn perpendicular to this object at the selected point. Starting beam is at a selected point.
Command is invoked _xline, , in which the user selects the object and reference point on it. Direct drawn perpendicular to this object at the selected point. Middle line is the selected point.
Beam line, polyline or line. Point on the object.
CAD drawing UTILITIES 248Mcconsthm
Create an auxiliary line to the corner along the bisector
Command is invoked _ray, for which the user selects two reference object. Ray is based on the bisector between the two reference objects.
Command is invoked _xline,in which the user selects two reference object. Direct built along the bisector between the two reference objects.
CAD drafting UTILITIES 249Mcconsttan
Create two parallel auxiliary lines tangent to the circle
Selected circle or arc that it may determine. Constructed two rays tangent to the circle, it is necessary to ask a series of positioning angles or point specified segment emanating from the center of the circle and parallel rays (link).
Selected circle or arc that it may determine. Constructed two lines tangent to the circle, it is necessary to ask a series of positioning angles or point specified segment emanating from the center of the circle and parallel lines (link).
Circle or arc.
CAD software UTILITIES 250Mcconstcc
Creating auxiliary circle another circle concentric circle or arc is selected.
Automatically construct a circle concentric with the selected object and specify the diameter (or the given number of diameters). The command completed after entering the series or after the forced shutdown command (Esc or right button).
Circle or arc.
CAD drawing UTILITIES 251Mcconstc2
Creating auxiliary circle tangent to the segment
Selected reference line object, the user specifies a point lying on the circle defined by the radius of the circle (the system offers the minimum possible radius which is equal to half the distance along the normal from the selected point to the segment, and controls the maintenance of value (greater or equal)). We construct a circle at two points of tangency (one point is given conditional perpendicular) and radius..
Beam line, polyline or line. Point belonging to the circle.
CAD drafting UTILITIES 252Mcconstkr
Creating auxiliary circle tangent to two segments
Selected two reference linear object and specify the diameter. We construct a circle at two points of tangency and radius.
CAD software UTILITIES 253Mcconstkr
Creating auxiliary circle tangent to three segments
Selected two reference linear object. We construct a circle at three points of tangency.The radius is calculated automatically.
CAD drawing UTILITIES 254Mcconstcircli
Creating auxiliary square circumscribing circle
Selected circle or arc, automatically builds a square, a circle is described. The context menu provides switching between inscribed and described by the square.
Circle arc.
CAD drafting UTILITIES 255Mcconsttc
Create an auxiliary line tangent to two circles
Selected consecutively two arcs or circles. Constructed beam tangent to the two circles, a definite choice (touch point – coming to a place of choice, the beginning of the beam – the first object).
Selected consecutively two arcs or circles. Constructed line tangent to the two circles, a definite choice (touch point – coming to a place of choice, the center line – the first object).
Two arcs or circles
CAD software UTILITIES 256Mcconst_circle
This is the counterpart nanoCAD assigning properties auxiliary geometry.
CAD drawing UTILITIES 257Mcconstxray
Creating a subsidiary of rays emanating from a single point
CAD drafting UTILITIES 258Mcconstxline
Creating auxiliary lines passing through one pointThis is the counterpart nanoCAD assigning properties auxiliary geometry.
CAD software UTILITIES 259Mcconstlines
Auxiliary linesThis command displays the settings nanoCAD Mechanica 23 with a pointer to the section Auxiliary lines.
CAD drawing UTILITIES 260Mcclineo
Enable / disable the auxiliary linesThis command automatically hides all auxiliary lines.
CAD drafting UTILITIES 261Mcconsterase
Remove auxiliary lines
This command automatically removes all auxiliary lines.
Calculator
The calculator is designed for complex mathematical calculations. The capabilities of the table and text editor are significantly expanded using the powerful functionality of the calculator.
The calculator is available in the table editor, text editor, when using the “Inquiry” utility in the “Value picker” dialog.
The “Calculator” dialog consists of a main menu and a set of grouped commands.
CAD software UTILITIES 262
Main menu
· Edit · Copy Ctrl+C – the command copies data from the input field. · Paste Ctrl+V – the command pastes the copied data into the input field. · View · NoteBook – command opens the notebook panel. · Degrees – the command switches the mode of calculating angles in degrees. · Radians – the command switches the mode of calculating angles in radians. · Expression – the command turns on the formula calculation mode. The input field is divided into two: on the left is the formula, on the right is the result.CAD drawing UTILITIES 263
Commands
Drop-down list “Precision” – sets the rounding digit of the calculation result.
CAD drafting UTILITIES 264
Switch “Degrees – Radians” – switches the angle calculation mode.
CAD software UTILITIES 265
Group of buttons “Mathematical operations”.
CAD drawing UTILITIES 266
The main group of calculator buttons. The composition of the buttons is similar to all standard calculators.
CAD drafting UTILITIES 267
Buttons for navigating table cells. Available when editing a table cell. It also shows the name of the currently edited cell.
CAD software UTILITIES 268
Button CAD drawing UTILITIES 269 to open the “Notebook” sidebar. It is possible to connect the spreadsheet editor of the “Notebook” tool. The additional sidebar lists tables from the notebook in a drop-down list. After selecting a table, its composition will be displayed. Double-clicking on a value from the table adds this value to the input field. This tool is useful when you need to perform routine calculation activities frequently.
CAD drafting UTILITIES 270
The “Insert” button is designed to insert the result of calculations from the calculator into an editable cell, a text entry field or the “Value picker” dialog.
The “Close” button closes the calculator dialog without transferring the value.
Button CAD software UTILITIES 271material designation.
This tool is designed to be inserted into the table, the technical requirements and specifications of the formatted string records on material and product mix. By pressing the button, a dialog box appears called material designation.
CAD drawing UTILITIES 272
Notebook
Button CAD drafting UTILITIES 273 Notebook
To enter recurring standard text expressions (abbreviations, symbols, etc.) used tool Notebook. This is a versatile tool for some editing tools nanoCAD Mechanica23, which is necessary to enter text. Notebook combines the functions of: storing a set of expressions and the structure of their placement in a separate file, input and placement of text expressions, input and placement of small tables, searching and editing tools introduced earlier records.
CAD software UTILITIES 274
Dialog Notebook divided into two parts. On the left side there is a tree structure of the notebook where the user selects the sections and pages notebook. In the upper part of the window control buttons notebook.
CAD drawing UTILITIES 275
CAD drafting UTILITIES 276Load from file. Opens the notebook file stored on disk.
CAD software UTILITIES 277Save. Saves the changes to the file in your notebook.
Important!
Recommended that you save a new notebook in a separate file in the first call to the tool Notebook using the button Save.
To search for a text string in a notebook has a special search tool, Right-click on any section or page of the section and in the context menu, call the command Find. Found links are placed in the section CAD drawing UTILITIES 278results
To accelerate the search procedure provided for viewing the latest expressions used in section CAD drafting UTILITIES 279history.
Management structure for the notebook with the buttons:
CAD software UTILITIES 280Add a partition
CAD drawing UTILITIES 281Add this page
CAD drafting UTILITIES 282Add a table
CAD software UTILITIES 283Delete tree item
In the notebook is allowed to create an unlimited number of sections and subsections, pages, and tables.
CAD drawing UTILITIES 284
Moving sections, pages, and tables for structural wood can produce a drag and drop (drag and drop).
Rename the selected section or page using the command Rename the shortcut menu.
CAD drafting UTILITIES 285Select / Copy the selected text. Transmits the selected piece of text pages into editable table cell. If the tree structure of the selected page or table in your notebook, the contents displayed on the right side of the dialog. Highlight the desired entry cursor, and turn the Select / Copy the selected text.
CAD software UTILITIES 286Edit Page. This button is used to activate the edit pages and style notebook. It becomes active only if the tree structure is selected page element or table. In edit mode, the tree structure becomes inactive, and the right side activates the Edit toolbar.
CAD drawing UTILITIES 287Editing tools page
CAD drafting UTILITIES 288Clear. Clears the current page
CAD software UTILITIES 289Load from file. Allows you to import an existing text file *.RTF MS Word.
CAD drawing UTILITIES 290Save the file. Allows you to record the content into a file *.RTF for use in MS Word.
CAD drafting UTILITIES 291Add item.
CAD software UTILITIES 292Remove the item .
CAD drawing UTILITIES 293Move up.
CAD drafting UTILITIES 294Move down.
CAD software UTILITIES 295Superscript. Includes character mode superscript.
CAD drawing UTILITIES 296Subscript. Includes character mode subscript.
CAD drafting UTILITIES 297Insert fraction. dialog box set the numerator and denominator.
Switch controls the display of the slash. CAD software UTILITIES 298CAD drawing UTILITIES 299Insert tolerance. Opens Tolerances.
CAD drafting UTILITIES 300Insert material. Opens material.
CAD software UTILITIES 301Calculator.
CAD drawing UTILITIES 302Tools for editing table
CAD drafting UTILITIES 303Insert Row.
CAD software UTILITIES 304Delete Row.
CAD drawing UTILITIES 305Insert Column.
CAD drafting UTILITIES 306Delete Column.
CAD software UTILITIES 307Rename column. Opens Properties column in which you specify the width and title of the selected column.
After editing, when you exit the notebook dialog appears – prompted to save the changes in a notebook.
CAD drawing UTILITIES 308
Magnet
Magnet used to draw complex paths based on existing graphics. The contour can be constructed by points or by sequential indication of adjacent segments or arcs.
Called by:
· from the context menu (Weld seam, Simplified weld joint) · button CAD drafting UTILITIES 309“Select contour with the magnet” in the dialog (Area array).An example of constructing a weld seam contour, based on an I-beam image inserted into the drawing
CAD software UTILITIES 310
1. We call the command CAD drawing UTILITIES 311“Weld seam”. A dialogue will open “Weld seam”.
2. Select the type of seam and click “OK”.
CAD drafting UTILITIES 312
3. In the context menu, select the command “Magnet”.
CAD software UTILITIES 313
4. We indicate the starting point of the contour.
CAD drawing UTILITIES 314
5. Sequentially move the cursor over the end points of the linear and arc sections of the I-beam contour.
CAD drafting UTILITIES 315
Deselection of the previous segment is made by re-pointing the cursor to the starting point of this segment or by the “Back” command from the context menu.
CAD software UTILITIES 3166. Use the “Close” command from the context menu to complete the construction of the closed contour.
CAD drawing UTILITIES 317
7. The weld will be built along the specified contour.
CAD drafting UTILITIES 318
Add selected
CAD software UTILITIES 319Command line: MCADDCOPY.
The command allows you to create a new object nanoCAD Mechanica based on the type and general properties of the selected object nanoCAD Mechanica.
1. Call the command “Add selected” – ADDCOPY.
2. Press the “Space” key (the option will turn on) if you want to insert the object in a cyclic mode.
3. Select an object to serve as a template. The paste command for the selected object type will run. The properties of the new object will match the template object.
