To Unload Map Underlay
Ribbon: Insert – Maps > Unload Underlay
Ribbon: Topoplan – Maps > Unload Underlay
Menu: Topoplan – Map > Unload Underlay
Command line: UNMAPVIEW
The command unloads the underlay content. Only the underlay contour is displayed.
You can load the underlay content back by the Load Underlay command.
The command works identically to the Map State underlay parameter on the Properties bar.
