Working with Database Objects
Parts Library nanoCAD Construction is a database and stored in a file with the extension * .mcs. By default, after installing nanoCAD Construction used base recorded in a file in the folder std.mcs data, housed in the installation directory of the program nanoCAD Construction .
Select another database possible, specifying the desired file in the “Database access“option in the settingsnanoCAD Construction “The path to the local database”.
Parts of the database can be exported as individual files, or import from external files into the current database of standard elements.
The basic tools for working with database objects
The basic tools for working with database objects are:
“Main menu- Construction – Library objects”
or on the toolbar “ Library objects”
- Tab manager
- Standard parts library
- Reinsert object
- Threaded fastening
- Rivet joint
- Markers, Groups
- Insert group
- Group objects
- Add marker
- Template wizard
- Cover
- Move up
- Move down
- Change hiden mode
- Regenerate supression contours
- Part trim
- Add part trim
- Remove part trim
- Add view
- Change representation
- Mirrow part
- Regenerate Std Parts
- User defined object
