Float Document Window
The Float Window command transfers a current document tab in a floating window state.
A document’s floating window is always in the foreground. It does not contain a command line, it cannot contain other document tabs. Functional panels cannot be attached to it.
In the Options dialog you can specify whether the floating window should contain the ribbon, menu or status bar.
Docked Document Window
The Dock Window command attaches the floating document window back to the main window as a document tab.
