Loading Python-script
Ribbon: Manage – Applications – Scripts > Python
Menu: Tools – Scripts > Python
Command line: PY, -PY
After calling the command, in the dialog box that opens, select the desired file with the py extension. The script execution starts immediately after the file is loaded.
To work with the PY command, Python 3 should be installed in Windows operating system and Active Scripting support (win32com.axscript) should be enabled. You can install Python Win32 extensions (pywin32) and Python Active Scripting support will be registered automatically.
