nanoCAD
Table of Contents
nanoCAD
General Information
Introduction
System Requirements
Program Installation
Program Registration
Launch of nanoCAD
Help System
Exit from nanoCAD
Trademarks
nanoCAD User Interface
Working with Commands
Redo Commands
Undo Commands
Undo-Redo Commands
Settings of the Right Button
User Interface
Interface. The nanoCAD Button
Quick Access Toolbar
Interface. Ribbon
Interface. Main Menu
Interface. Toolbars
Interface. Drawing Window
Interface. Context Menu
Interface. Properties Bar
Command Line
Status Bar
Restore UI State
Managing Interface Elements
Application Look
Working With Documents
Creation of New Document
New Document Creation
Template Usage
Saving a Document
Saving Document
Auto Saving and Backup
Export
Exports
Integration with CAE Fidesys
CAD Standards
CAD Standard
Creating a Standards File
Checking Standards
Standards Check Options
Utilities
Utility
Document audit
Audit geometry
Recovery of document
Purging of document
Convert to 2D
Text Encoding Conversion
Work with Documents
Opening a Document
Drawing Properties
Closing a Document
Import
Import PDF
Importing PDF Underlay Data
Create Transmittal Package
File Explorer
Drawing Comparison
Tuning nanoCAD
Transferring user interface
Tuning program parameters
Profiles
Profile quick setting
Graphic subsystem settings
Customize User Interface
Customize Users Interface
Ribbon Tab
Main Menu
Toolbars Tab
Toolbars Display Settings
Accelerators Tab
Object Actions Tab
Status Bar Tab
Rollover Tooltips Tab
Aliases Tab
Create New Command
Create Virtual Command
Design settings
Design setting
Main Options Tab
Standard Elements Tab
Symbols Tab
The Forms tab
3D Tab
Settings of Layers profiles
Drawing units
Scale List
System Variable Monitor
Coordinate Systems
User Coordinate System 16000
UCS Icon
Named UCS
UCS for viewports
Coordinate system
Aligning UCS to an Object
New Origin for UCS
UCS View
Changing direction of Z axis
Dynamic UCS
Precision tools
Precision tools
Snap and Grid mode
Snap and Grid Modes
Drawing limits
Snap to raster objects
Snap to Raster Object
Settings of raster snap
Precision mode
Polar Tracking mode
Object snap mode
Object Snap tracking mode
Display of snap elements
ORTHO mode
Dynamic Input
Precision Tools
2D Constraints
Graphic Display Management
3D Navigation
3D Orbit
Free Orbit
3D-Navigation View Modes
3D-Fly
3D-Walk
Plan
Bounding Prism
View cutting planes
Order of objects
Order of object
Bring to Front
Send to Back
Bring Forward
Send Backward
Bring Texts to the Front
Bring Dimensions to the Front
Send Hatches to the Back
Isolate Objects
Hide Objects
Undo isolation step
Redo isolation step
Unisolate Object
Viewports of Model Space
Viewport of Model Space
Display modes
Visual styles
Managing named views
Isodraft
Drawing regeneration
Objects’ Properties
Line Types
Line Type
Line type Editor
“Properties” bar
Properties panel
Layers
Tools to work with layers
Make Object’s layer current
Layer walk
Match layer
Change to current layer
Copy objects to new layer
Isolate
Layer off
Turn on all layers
Layer freeze
Thaw all layers
Layer lock
Layer unlock
Merge layer
Delete layer
Tools to Work with Layers
Layers Dialog Box
Layer previous
Objects’ Property
Drawing Explorer
Select Color Dialog Box
Geometric objects
Point
Infinite Lines
Linear Objects
Line by two points
Polyline
3D Polyline
Multiline
Multiline Styles
Polygon
Rectangle by two points
Rectangle by three points
Helix
Curved Objects
Curved object
Arc by three points
Arc by start, center and end
Arc by start, end and angle
Arc by start, end and radius
Circle by center and radius
Circle by center and diameter
Circle by diameter
Circle by three points
Donut
Splines
Ellipse
Add selected
Geometric object
Size and style of points
Editing Objects
Selection of objects
Selection of all objects
Remove from Selection
Leave in Selection
Invert Selection
Select Similar Objects
Quick selection of object
Object Selection
Ways to edit objects
Ways to edit object
Copy of Objects Properties
Copy object
Lengthen Objects
Trim Vectors
Smart Trim
Extend Vectors
Break Vectors
Break Vectors at Point
Break All Vectors at Point
Reverses
Join Object
Editing a Polyline
Editing a Spline
Simplify Splines
Commands to edit objects
Erase
Copy
Mirror
Offset
Array
3D Array
Delete duplicates
Move
Rotate
Scale
Stretch
Align
Distributing copies
Divide
Measure
Chamfer
Fillet
Explode
Explode all nanoCAD objects
Editing object
Blocks
Block
Creating a Block
Block Insertion
Block Attributes
Creating Block Attributes
Block Attribute Manager
In-Place Attribute Editing
Block Editor
Proxy Objects
Proxy Object
Removing Proxy Objects
Exploding Proxy Objects
External references control
External reference control
Bind external references
Renaming Named Objects
Underlays
Underlay
Insert Underlay
Show boundary
Show boundary definition
Boundary
Groups of objects
Insert External Reference
Edit references
Exploding a block reference
Hyperlinks
Working with raster images
New Image from Selection
Save Objects to a File
Save Screenshot to a File
New Image
Image Adjust
Image Quality
Resizing raster image
Changing image resolution
Cropping of Raster Images
Mirroring
Rotation
Deskewing
Correction by four points
Calibration
Color correction
Color corrections
Correction by histogram
Gamma correction
Editing color palette
Filtering color raster images
Blur
Adaptive Blur
UnSharp Mask
Median
Color reducing
Colour reducing
Binarization
Adaptive binarization
Color Separation
Color reduction
Monochrome filtering
Monochrome filterings
Removing speckle
Filling holes
Smoothing
Thinning
Thickening
Contour
Inversion
Raster drawing
Raster drawings
Pixel drawing
Floodfiling
Editing raster text
Trace modes
Trace methods
Forced tarce
Trace polyline
Conversion options
Recognition tab
Options tab
Separate tab
Trace tab
Texts tab
Train OCR
TIFF saving options
JPG and JPEG saving options
Insert raster image
Separate Raster Image
Embed Raster Image
Image settings
Separation by type and size
Rasterization
The Filling and Hatch command
Gradient fill
Fast Hatch
Fast Gradient
Modify Hatched Areas
Work with Text
Work with Texts
Text
Multiline Text
Editing Text
Creating a text style
Spellchecker
Find and Replace Text
Justify Text
Text Fit
Explode text
Change Text Case
Quick Text mode
Field
Update Field
Edit Field
Convert Field to Text
Dimensioning
Dimensionings
Ordinate dimensioning
Group dimensioning
Base dimensioning
Chain dimensioning
Radial dimensioning
Big radius dimensioning
Diameter dimensioning
Angular dimensions
Arc length dimensioning
Dimensions editing
Dimension editing
Oblique dimension
Break and Restore dimensions
Dimension styles
Dimension style
Modify a dimension style
Multileader
Multileaders
Aligning multileaders
Collecting multileaders
Multileader Style Manager
Notes
Mechanical note
Construction note
Comb leader note
Section note
Node note
Linear aligned note
Chain note
Editing the leaders
Tables
Table
Editing tables on the drawing
Cell Properties dialog
Import, Export from MS Excel
Page Division
Convert tables
Expression builder
Report creation
Grouping and merging cells
Insert material
.dwg Tables
Insert .dwg table
Table Styles .dwg
Getting Inquiry
Distance
Point Coordinates
Cumulative Length
Cumulative Area
List
Inquiry
Mass Properties
Set Variable
The Edit Command
The DDEdit Command
The FEdit Command
The In Place Edit Command
Parameters Redefinition
Regenerate
Shape
Topographic Hatches
Boundary
Region
Solid
Wipeout
Revision Cloud
Calculator
Notepad
3D Modeling and Visualisation
Surfaces
Box
Wedge
Cone
Sphere
Torus
Pyramid
Dish
Dome
Mesh
3D Mesh
3D Face
Light Sources
Light Source
Point Light
Spotlight
Distant Light
Weblight
Materials
Material
Materials Browser
Material Editor
Surface
3D-Component Features
Tool Palettes
Tool Palette
Point Clouds
Point Clouds Display Settings
Point Cloud Display Style
Clip Point Clouds
Point Clouds Section
Information
Point Cloud Info
Point info
Point Cloud
Import of Point Clouds
Export of Point Clouds
Extract from View
Clip Point Clouds by Fence
Clip Undo
Reset All Clips
Point Cloud Vertical Section
Software Extensions
Software extension
NRX and LISP file loading
.NET application loading
JScript loading
VBScript loading
NSF files loading
Work with LISP-applications
ncad.lsp
Command scripts
Script Editor
Run from Command Lline
Topoplan module
Creating Geopoints
Description Key Sets
Create A Description Key Set
Modify A Description Key Set
Delete A Description Key Set
Description Keys
Modify The Description Key
Delete The Description Key
The Description Keys
The Geopoint Object
Convert The Points
Creating surfaces
Create TIN by points
Exploding a cloud into points
Import elevation grid
Converting model to 3D Faces
Converting model to SubMesh
Tools to work with surfaces
Flip edge
Delete edge
Add vertex
Delete vertex
Change elevation
Moving a vertex
Add structure line
Mesh boundary
Cut mesh
Classification mesh
Create contour lines
Delete Contour Lines
Creating bergstriches
Contour Lines Labels
Building a profile line
Projecting a line onto a mesh
Correction of zero elevation
Texturing and Calculation
Flat Texture Overlay
Raster texture Mapping
Mesh Coloring by Height
Calculting surface area
Calculating surface volume
Import and export
Import geopoints
Import from LandXML
Export to LandXML
Import from GIS
Export to GIS
Topoplan
Importing Geo-linked Rasters
Add Measurement File
Mesh Seal Holes
Hide Frames
2D Slope
Create Layouts by Frames
Save to Measurement Archive
3D Slope
Delete frames
Save as Geounderlay
Adding Edge
Conventional Signs
Create View Frames
Measurement Archive
Export Geopoints
Attach GeoUnderlay
Import measurements
Mesh Simplification
New Topoplan
Surface Difference
Create Geopoints
Mechanica Module
Intro
Basic knowledge
Workspace
Toolbars
Paper space commands
Special characters and fonts
The Geometric constructions
The parameters hatch
Mechanica’s Help System
The Regen
The Compatibility
The context menu entry fields
The Special keys
The nanoCAD integration
The Template
About a program
A cursor-pointer
The Menu
The Copyrights and Licenses
The Functional panels
Jobs for the current scale
Settings
The Configuration utility
A Position
The Databases access
To Comb leader note
Edit shaft
The Line of break
Marking and branding
The Layers and profiles
All Common settings
Specification
The Hot keys
The Views, sections
To Chain note
The Table
Surface texture
Mechanica’s 2D views
Specification leader
Pipes
Mechanica’s Common settings
Mechanica’s Notes
Mechanis’s Quick options
new 23
Holes
Mechanica’s Design
Construction lines
IDF Convert
Mechanica’s Dimensions
Mechanica’s Node note
Mechanica’s Beam calculations
Mechanica’s Drawing borders
Mechanica’s Line Types
Mechanica’s Welds
Mechanica’s fixed joints
Mechanica’s Symbols
Mechanica’s gradient
Mechanica’s settings
Mechanica’s cutting surface
Mechanica’s standard elements
Mechanica’s special settings
Dimension marker
Mechanica’s notifications
Mechanica’s forms
IFC
Mechanica 3D
Mechanica’s main options
Mechanica’s note
Hole tables
Sort kinds of cuts …
Standard
Tolerances
Mechanica’s Notepad
Mechanica’s construction note
Mechanica’s Edit
Markers, groups
Mechanica’s Inserting Groups
Mechanica’s Template Wizard
Mechanica’s universal marker
Mechanica’s User Groups
Control overlapping objects
Mechanica’s Move up
Mechanica’s move down
Mechanica’s dependences
Recognition graphics drawings
Tab “Objects”
Mechanica’s Tab Manager
Mechanica’s table settings
Mechanica’s reinsert object
Mechanica’s calculations
Mechanica’s Mirror Part
Mechanica’s add part trim
Mechanica’s remove part trim
Mechanica’s Add View
Mechanica’s properties
Mechanica-Tab “Library”
Mechanica- Dialog “Overrides”
Designing
Design details of rotation
Accommodation details “cover”
Dynamic display sizes details
Setting step drawing
Remove fasteners
Group inserting objects
Mechanica: Threaded fastening
Import PCB format IDF
Templates bearings
Sequence of piping design
Mechanica: Rivet joint
Shaft chamfer
Placing snap ring groove
Editing section of the shaft
Shaft fillet
Accommodation details “Glass”
Engineering Analysis
Calculation of gears
Dimension chains
Calculation wizard
Editing Material Database
The calculation results
Fastening calculation
Drawing Specifications
Mechanica: Specification
Setting Specifications
Balloons
Position Align
Mechanica: Project Manager
Drawing Design
Mechanica: Drawing borders
Mechanica:New title wizard
Mechanica: New border wizard
Mechanica: Tables
Mechanica: Report Template
Mechanica: Table editor
Mechanica: Using styles
Mechanica: Division by page
Mechanica: Table recognition
Mechanica: Create reports
Mechanica:Cell Properties
Mechanica: Conversion options
Mechanica: Basic tools
Mechanica: Using Variables
Mechanica: The Tables
Mechanica Utilities
Mechanica: Notebook
Mechanica: Add selected
Mechanica: Creating a hatch
Mechanica: Objects numeration
Mechanica: Centerlines
Mechanica: Breaks
Mechanica: Fillet
Mechanica: Chamfer
Mechanica: Calculator
Mechanica: Magnet
Mechanica: Steps of an array
Mechanica: Measurements
Mechanica: Plate Array
Mechanica: Rectangular array
Mechanica:Fragment Copy
Mechanica: Construction lines
Mechanica: Area array
Editing
Mechanica: Editing
Mechanica: Group Edit
Mechanica: Explode primitives
Mechanica: Edit in-place
Mechanica: Regenerate
Mechanica: Find and Replace
Mechanica: Quick selection
Mechanica: Explode all
MechWizard
Mechanica: Form editor
Mechanica: new 1
Mechanica: Collection Editor
Mechanica: new 3
Mechanica: new 4
Mechanica: new 5
Mechanica: new 6
Mechanica: Form properties
Mechanica: new 7
Mechanica: new 8
Mechanica: new 9
Mechanica: new 10
Mechanica: new 11
Mechanica: new 13
Mechanica: new 14
Mechanica’s: Form Editor
Mechanica: new 16
Mechanica: new 17
Mechanica: new 18
Mechanica: new 19
Mechanica: new 20
Mechanica: Examples
Mechanica: Create sketch
Mechanica: Script Master
Mechanica: Hatch contour
Mechanica: Symmetry axis
Mechanica: Test Model
Mechanica: Methods
Mechanica: Display conditions
Mechanica: ScriptMaster
Mechanica: Table resources
Mechanica: Object
Mechanica: Array
Mechanica: Script
Mechanica:Implementation
Mechanica: Description
Mechanica’s: Script
Mechanica: Parameters
Mechanica: Compound objects
Mechanica: Object tree
Mechanica: Basic properties
Mechanica: Check boxes
Mechanica:Insert point
Mechanica: Current script
Mechanica: Set Parameter
Mechanica’s: Editing
Mechanica: Working planes
Mechanica: MechWizard
Mechanica: Graphics
Mechanica: Object’s graphic
Mechanica: Other functions
Mechanica: Panel HB
Mechanica: BIM
Mechanica: IFC viewer
Construction Module
Formats
Working with standard formats
New title wizard
New border wizard
texts
Technical conditions
Technical parameters
Text editing
Construction text
The tables
Table editor
The Conversion options
Using Variables
Basic tools
Cell Properties
Using gestures for shortcuts
Report Template
Import, export from Excel
Split the table by pages
Table recognition
Interface Expression Editor
Create reports
Using styles
Show object relations
Binding to a table cell
Division by page
A Table
Utilits
Objects numeration
Centerlines
Measurements
Arrays for arc trajectory
The Fillet
Breaks
The Rectangular array
The Chamfer
The Area array
The Anchor
The Magnet
The Plate Array
Notebook
Static beam calculation
Fragment Copy
Creating an array of objects
Creating a hatch
Steps of an array
Add the selected
The Calculator
Denote
Position marker
Gradient symbol
Stationing
Correction Mark
Position
Fragment mark
Node
BIM
IFC import settings
Model check
IFC viewer
BCF
Edit
Group Edit
Export drawing file
Edit in-place
Parameters Redefinitions
Explode all
Find and Replace
Viewport context toolbar
Explode primitives
The Editing
Regeneration
Quick selection
Architectural
Stairs
Join wall
Make Corner
Extend wall
Polygonal wall
Finishing
List of columns
Import IFC plans
Wall modifier
List of materials
Wall
Add Object
Convert to wall
Explication of rooms
Door
List of openings
Column
Room
Break the wall
Sheet of decorations
Parameters
Convert to wall modifier
Window
Trim wall
Symbols
Hole group
Communication
Create trace
Project Manager
Equipment
Sample create label
Template library
Automatic tracing
Library
Create equipment
Trace
Attribute library editor
Port
Table of connections
Create port
Decor_params
Architectural decisions
Decor Table
Hot keys
Similar object
The Mechanical note
The Chain note
Correction marker
The Node
Views, sections
Additional extension lines
Design
new 13
Dimensions
Beam calculations
The Construction note
Construction axis
Line of break
Gradient
The Notes
The Section note
Construction: Holes
Engineering networks
Databases access
Common settings
The Node note
Plane elevation marks
Welds
Distribution range
Axes array
Edit Option
Marker
Notifications
The Settings
Designation stationing
The Symbols
3D
The Common settings
3D. Pseudo section properties
2D views
Elevation mark
Standard elements
The Comb leader note
End markers
Layers and profiles
The Line Types
Fixed Joints
Main options
The Linear aligned note
Fragment
The Notepad
Construction: IFC
Boundary form
Quick options
The Position
Standard
The Technical conditions
Forms
Drawing borders
Cover
Change hidden mode
Move down
Move up
Engineering_analisys
Axis
Array of polar axes
Rename construction lines
Circular construction axis
Separate markers
Similar construction line
Array of orthogonal axes
Single axis
Arc construction axis
Adding axis to the array
Add markers
FormEdit
new 2
new 3
new 4
new 5
new 6
new 7
new 8
new 9
new 10
new 11
Form properties
The new 13
new 14
new 15
new 16
Form Editor
Collection Editor
new 19
new 20
The Intro
Intro
weld
Fixed joint
Welding…
Simplified weld joint
Simple welding
Weld seam
Edge preparation
dbscript
Specification object
Functions to process surfaces
Object’s graphic
Panel HB
Appendix 3. Object Classes
Localization mechanism
Blind GOST 16076-70
Object versioning support
I-profiles GOST 19425
Other functions
Syntax scripting language
Eventive Object’s model
Abstract model of the detail
Graphics
construction MechWizard
Script
Set Parameter
Working planes
Managing Dependencies
Table resources
Master dependencies
ScriptMaster
Suppression contour
Conditions rendering
Object tree
The Parameters
Object
To Edit
The Script
Description
Symmetry axis
Basic properties
Test Model
Implementation
Create sketch
Methods
Calculation of parameters
Hatch contour
Check boxes
Current script
Insert point
Parameter Properties
Compound objects
The Array
Script Master
Show / Hide parameters
Display conditions
Level
The Elevation mark
Recalculate level marks
Level mark on plane
Align level marks by arrows
Configuration
Configuration Utility
Graphic
Similar object
Symmetrical rectangle
Basic_know
Functional panels
Template
Object-dependent parts
Context menu entry fields
nanoCAD integration
The cursor-pointer
Jobs in the current scale
Selected and allotted object
The Help system
Regen
Parameters hatch
The Toolbars
About the program
Special keys
The Paper space commands
Compatibility
Intelligent controls grips
mDimension
Angle dimension
Ordinate dimension
Creating a dimension style
The Offset dimension
Diameter
Comparing Dimension Styles
Edit dimension
Dimension Style Manager
Modify dimension style
Auto
Dimensions Chain
Linear dimensions
Large arc radius
Group dimension
The Oblique dimension
Arrange dimensions
Radius
Baseline dimension
Note
Save template note
Adaptive note
The Distribution range
Contruction Module: Node note
hatch
Bound forms
Design
Rivet joint
Threaded fastening
work_standart_element
Simplified / Full View
User defined object
Calculations
Dependences
Add part trim
Reinsert object
Standard parts library
Tab “Objects”
Override main lines
Tab “Library”
Dialog “Overrides”
Remove part trim
Tab Manager
Properties
Working with Database Objects
Regenerate STD parts
Mirror Part
The table settings
Add View
view
Section
To View
View and Section Label
Marker
Create custom groups
Universal marker
User Groups
Template Wizard
Inserting Groups
Lessons
Work with Layouts
Work with Layout
To create a new layout
Copy layout
Copy layout without viewport
Save a Layout as a template
Delete Layout
Rename Layout
Layouts Manager
Viewports
Viewport
Create a rectangular viewport
Edit Layout Viewports
Change Space
Export Layout to Model
Create a polygonal viewport
Create a viewport by object
Document Plot
Documents plot
Page Setup Manager
Plot Preview
Plot Style Manager
Plot
Batch plot
Internal PDF-plotter
Model space and paper space
EDS
EDSs
Sheet Set
Sheet set tree elements
Sheet Set Properties
Sheet set property
Sheet set custom properties
Blocks in the Sheet Sets
Blocks in the sheet set
View label blocks
Callout blocks
Sheet sets
Create Sheet Set
Open Sheet Set
Messages
Save changes?
Saving in demo mode
Switch it to 3D render mode
Version 23
Hide All Features
Invert Clip
Copy with Base Point
Isolate Feature
Path Array
Associative Arrays
Setting Clip
Copy OLE-link
Detrmining the Diameter
Paste Special
Determining the Radius
Paste to Original Coordinates
3D Module
Batch File Processing
Explode Geometry
Cut
Align the Viewport Objects
Open OLE-Object
Clip Clouds by Cylinder
Update All OLE-Links
Visual Styles Editor
Isolate All Features
Geopoint Object
Paste as Raster
Hide Feature
Paste as Block
Reset Block
Clip Map Underlay
Selection of Overlaid Objects
Point Clouds Data Formats
Object 3D Snap
Unload Map Underlay
Clip Clouds by Sphere
Paste
Arc Text
Show All Features
Feature Isolation Reset
Edit Polyline Segments
Load map underlay
Import Cloud Data from DBMS
Modular Program Configuration
Isolate Features
Offset of a 3D-Polyline
Insert Map Underlay
Float Document Window
Hatch Dialog Box
Create Layer
Insert OLE-Object
3D Block Editor
Import of KML/KMZ files
Updating Links of OLE-Objects
Rectangular Array
Polar Array
Edit Array
Developer’s Guide Database
Distributing Objects by Layer
Arrays
Groups of Object
Version 24
Area
Add a Group of Points
Formation of a Legend
Modify a Description Key
Creating Hatch
Displaying a Point Cloud
Convert Points
Creating Geopoints by Surface
Create Description Key Set
Delete a description key
Modify Description Key Set
Layers Functional Bar
Layer Translator
Hiding the Point Cloud
Offset Dimension
Create a Description Key
Texture Editor
Delete Description Key Set
Version 25
Loading Python-script
The Mesh Seal Holes
Quick Properties
To Save as Geounderlay
To Modify a Description Key
The Clip Map Underlay
All Line Types
The Offset of a 3D-Polyline
The IFC Viewer
To Export to GIS
To Hide the Point Cloud
To Attach GeoUnderlay
The new 19
Interface. Search Field
The Mirroring
To Unload Map Underlay
The Clip Point Clouds
Geocalculator
To Add Measurement File
To Import measurements
Vector Correction
To Display a Point Cloud
The Load map underlay
Plotter Settings
To Import from GIS
To Create a description key
Save the Measurement Archive
The Import of KML/KMZ files
To Delete a description key
Paper Formats
Point Cloud Project Manager
Problem Report
Creating a Coordinate System
Download as PDF
new 19
Collection Editor
new 20
new 19
Figure. Insert a simple bitmap to the form.
Properties command.:
Collection Editor
new 20
Yes
No
Your name *
Your e-mail address *
Comment *
