Ribbon: Topoplan – Utilities > Project Objects onto a Surface
Menu: Topoplan – Utilities > Project Objects onto a Surface
Toolbar: Topoplan Utilities > Project Objects onto a Surface
Command line: NG_MESH_PROJECT_OBJECTS
The command projects objects – blocks, points, geopoints, texts, Mtexts – onto the surface. The elevation (Z coordinate) of the listed objects changes to the surface elevation. After running the command, specify the Network object in the drawing.
