Size and style of points
The Point Style dialog box is used to display and change the current style and size of a point. The current display style of the point is highlighted. Click on any symbol to change display style.
Parameters:
| Point Size: | Specify point symbol size. Entered value can specify a size in percentage of screen size or in absolute document units. |
| Set Size Relative to Screen | Shows point symbol size as a percentage of the screen size (the point size is not changed if the screen is zoomed). |
| Set Size in Absolute units | The point symbol size is changed if the screen is zoomed (increases or decreases). |
To change the current size and style of a point:
- Select the style.
- Enter the point size in the Point Size dialog.
- Turn the required display size of point symbol on.
Info: NanoCAD is an easy-to-use, cheap, and yet professional, CAD application for personal computer, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
