Editing the leaders
When editing the leaders, the same dialog box as when creating these leaders will be opened, but some additional icons that are blocked when creating leaders will be available (for example, the Add extension line, Select line and others).
The dialog box to edit the leaders (if Yes is chosen for the Program objects option of the Settings nanoCAD Int dialog box on the Main options tab of the Edit – By double-click section (the Tools menu – Advanced Settings)) can be opened:
- by double-clicking on the leader;
- by right button clicking with CTRL pressed on the leader.
The edit and fedit commands allow you to open the dialog box to edit the leaders, it does not matter whether Yes is set or not.
You can also open the dialog box to edit the leaders:
- by placing the cursor over the leader and selecting Edit in the tooltip:
NOTE: To invoke the dialog this way you should choose Yes for the Show tooltips option (the nanoCAD – Options dialog box – the Main option tab – the Tooltips section):
- by selecting the leader, pressing the right button and choosing the Edit command in the context menu.
The In-place edit command (ipedit) or left click on the leader with CTRL pressed allow you to edit the text of leader directly in the drawing, it does not matter what value is chosen for the Program objects option.
It is very easy to edit leaders with grips (for more information, see “Advanced grips”).
You can also detach, append and edit extension lines with the appropriate commands from the Draw menu – the Notes item or from the Utilities toolbar.
Detach leader
To detach a leader, it is necessary to select it in the drawing. The leader will be detached immediately after its selection.
Append leader
To append leader:
- Specify a point on the object.
- If necessary, specify the number of intermediate points forming a break of leader.
- Specify a point on the required leader inserted in the drawing, to finish the command.
Edit leader
To edit leader:
- Select a leader in the drawing.
- Specify a point on the required leader to fix a new position for the leader.
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD application for personal computer, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software supports creative, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
