Form Editor
Database objects nanoCAD Construction supports the use of custom dialogs for inserting and editing. Creating such dialogues (forms) is made in Form Editor, which can be accessed from the dialog boxes Create Group, Create marker and Object Wizard .
Button Open the form editor.
File
Test. Opens the form for viewing and testing.
Output. Closes the form editor.
Correction
Cancel. Cancels the previous execution of operations.
Cut, copy, paste . Command working with the clipboard.
Select all. Selects all the controls on the panel shape.
Remove. Deletes the selected controls from the form.
Group. Group the selected controls.
Ungroup. Cancels the grouping selected controls.
View
By … edge. Alignment commands selected controls along one edge.
Align dimensions. Aligns the selected controls dimensions.
Above and below. Reverses the order of the tab selected control by moving it up a level or down
Forward, backward . Changes the tab order of the selected control by moving it to the first or the last level.
Tab order . Includes display serial numbers tab controls.
To set the tab order to be pressed sequentially controls on the left mouse button. Tab order will be set according to the sequence control option.
Properties. Enables and disables the additional window Properties.
Variables. Enables and disables the additional window variables.
Grid Turns on and off the grid and snap to grid.
Indents . Enables or disables the frame shape
Insert
There are commands insert controls
- Input field ..
- Checkbox ..
- Switch.
- List.
- List from the database.
- Combo box.
- Combo box from the database .
- Text.
- Group.
- Figure.
- Panel.
- Button.
- Table with filtering.
- Table.
- Types and performance.
- Viewing.
Forms panel
On the forms produced occupancy controls.
In the context menu of the forms are available editing commands: cut, copy, paste, group, ungroup.
To add a control to the form by one of the following ways:
Select the desired control from the menu Insert or toolbar. Specify the insertion point and set the dimensions of the control panel on the form.
After adding the control you want to bind it to a field in the Properties.
In the open window, Variables , select the variable for which you want to add a control. Left-click on the variable in the list, and holding down the mouse button, move the cursor to the panel shape. Release the mouse button. Panel forms added group controls – text and input field .
If you insert a control from the window variables hold down Control, then it is possible to select the type of control.
Selection of the control panel forms can be accomplished in several ways:
Single click of the left mouse button. Selected one control.
Single click of the left mouse button while pressing Control . If the control is not selected, it is added to the current set. If a control is selected, it is removed from the current set.
Choosing a crossing . Click the left mouse button in the space bar form. Holding the button down and dragging a selection box set. Selected controls that are fully or partially captured by the selection frame.
Editing the size of the control is done by using the “ grips “. When the grid is resized with a certain step.
Changing the position of the selected controls performed with the left mouse button on one of the selected items. When the grid movement occurs incrementally.
Align controls
In the menu View available commands align controls on edge and size.
Controls aligned to the left, and then by size .Grouping controls
Working with multiple controls may need to be fixing their relative position. If grouping is fixed relative position of the controls, and when you move one of the other grouped elements also move.
Select panel forms controls and issue the Group. Selected controls will be grouped.
Removing Controls made the command Delete.
Test the form
Before completing the form creation is recommended to execute the test to view the form.
Variables window
In the Variables are parameters of the object ( marker , database object , group ).
Icon marked parameters that are associated with controls editable form
Properties window
In the Properties lists the properties of the selected controls on the form. At the bottom there is a line prompt with a brief description of the selected property
