Create New Command
Add custom command to the nanoCAD interface.
Custom command should be loaded with Tools – Application > Load application… and should be automatically loaded for each new nanoCAD session
1. Call Create command context menu in the command list.
2. Set command parameters in a Create command dialog box.
3. Set new command parameters in the Create command dialog box. The highlighted fields are mandator for filling.
Command parameters:
| UID | Element identifier. |
| Intername | The name of loaded command. It can contain the following symbols: A-Z, 0-9, ), (, _, #, $. No spaces. Intername often fits with UID. |
| Localized name | Localized name of command. It can contain national characters and the following symbols: A-Z, 0-9, ), (, _, #, $ . No spaces. |
| Execution context | Select Document if the command should work on opened document. Select Application to use command when no opened document. |
| Weight | Priority of command when several commands run at once. Lowest weight has the highest priority |
| Display name | The name of command, displayed in menu. |
| Tooltip text | Displayed when cursor pointing to the object. |
| Status text | Text in the command line. |
| Bitmap DLL | DLL-file containing the command |
| Icon | Icon of command, displayed on toolbars and menus. |
The command appears in the list of tools in the right part of the Customize user interface dialogue. It can be placed in the menu, toolbar or command line.
