Removing Proxy Objects
The command is used to remove proxy objects. Pre-selection of objects is acceptable. If there are no selected objects, the command makes a query:
Select objects or [?/Drawing]:
In response to te query it is possible to select objects or specify an option. The Drawing option is used to select all proxy objects in a drawing, including objects on other drawing tabs and objects without graphics, which cannot be selected in another way. After the user specifies this option, the system will perform removal and report on the number of detected and deleted proxy objects, for example:
1526 proxy objects found, including 348 graphical proxy objects.
1526 proxy objects removed, including 348 graphical proxy objects.
Option ? makes a query to change the method for selecting objects (similar to SELECT command):
Select an option or
After changing the method, it is necessary to select proxy objects for removal.
Objects that are not proxy objects may get in the set of objects selected for RMPROXY command. No actions will be performed with such objects.
Info: NanoCAD is a simple, inexpensive, and yet powerful, CAD software tool for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software provides progressive, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
