Working with Database Objects
Parts Library nanoCAD Mechanica23 is a database and stored in a file with the extension * .mcs. By default, after installing nanoCAD Mechanica23 used base recorded in a file in the folder std.mcs data, housed in the installation directory of the program nanoCAD Mechanica23.
Select another database possible, specifying the desired file in the “Database access“option in the settingsnanoCAD Mechanica23 “The path to the local database”.
Parts of the database can be exported as individual files, or import from external files into the current database of standard elements.
The basic tools for working with database objects
The basic tools for working with database objects are:
“Main menu – Mechanica – Standard parts”
or on the toolbar “Standard parts”
CAD drafting WORKING WITH STANDARD ELEMENTS 0
· CAD software WORKING WITH STANDARD ELEMENTS 1Tab manager · CAD drawing WORKING WITH STANDARD ELEMENTS 2Standard parts library · CAD drafting WORKING WITH STANDARD ELEMENTS 3Reinsert object · Markers, Groups · CAD software WORKING WITH STANDARD ELEMENTS 4Insert group · CAD drawing WORKING WITH STANDARD ELEMENTS 5Group objects · CAD drafting WORKING WITH STANDARD ELEMENTS 6Add marker · CAD software WORKING WITH STANDARD ELEMENTS 7Template wizard · Cover · CAD drawing WORKING WITH STANDARD ELEMENTS 8Move up · CAD drafting WORKING WITH STANDARD ELEMENTS 9Move down · CAD software WORKING WITH STANDARD ELEMENTS 10Change hiden mode · CAD drawing WORKING WITH STANDARD ELEMENTS 11Regenerate supression contours · Part trim · CAD drafting WORKING WITH STANDARD ELEMENTS 12Add part trim · CAD software WORKING WITH STANDARD ELEMENTS 13Remove part trim · CAD drawing WORKING WITH STANDARD ELEMENTS 14Add view · CAD drafting WORKING WITH STANDARD ELEMENTS 15Change representation · CAD software WORKING WITH STANDARD ELEMENTS 16Mirrow part · CAD drawing WORKING WITH STANDARD ELEMENTS 17Regenerate Std Parts · CAD drafting WORKING WITH STANDARD ELEMENTS 18User defined object · CAD software WORKING WITH STANDARD ELEMENTS 19Add constraint · CAD drawing WORKING WITH STANDARD ELEMENTS 20Connect objectsTab Manager
CAD drafting WORKING WITH STANDARD ELEMENTS 21Main menu: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 22Tab manager.
CAD drawing WORKING WITH STANDARD ELEMENTS 23Ribbon: Mechanical – Standard parts – CAD drafting WORKING WITH STANDARD ELEMENTS 24Tab manager.
CAD software WORKING WITH STANDARD ELEMENTS 25Toolbar: CAD drawing WORKING WITH STANDARD ELEMENTS 26Tab manager (on toolbar “Standard parts”).
CAD drafting WORKING WITH STANDARD ELEMENTS 27Command line: MCTABS.
Object Manager nanoCAD Mechanica 23 includes the following tools:
· Manager database of standard objects · Objects · Pruning of standard parts · Finding and replacing text · Copying propertiesTab “Library”
Tab “Library” object manager is a universal means of access to the standard database objectsnanoCAD Mechanica23.
Details in the database are classified according to their design purpose.
CAD software WORKING WITH STANDARD ELEMENTS 28
Management and structure the database by using the toolbar and the context menu that includes the ability to add, delete, or rename folders.
Toolbar
· CAD drawing WORKING WITH STANDARD ELEMENTS 29Del object. Removes the selected item or folder from the database · CAD drafting WORKING WITH STANDARD ELEMENTS 30Add folder. Adds a folder to the database · CAD software WORKING WITH STANDARD ELEMENTS 31Insert object. Performs insert the selected database object in the drawing · CAD drawing WORKING WITH STANDARD ELEMENTS 32View. Includes preview of database objects · CAD drafting WORKING WITH STANDARD ELEMENTS 33Search panel. It includes search bar facilities on base · CAD software WORKING WITH STANDARD ELEMENTS 34Refresh. Updates the tree base in the object manager. Press this button after making changes to the databaseContext menu
The context menu has a different structure depending on call.
In the palette – the object context menu:
CAD drawing WORKING WITH STANDARD ELEMENTS 35
In the palette – the context menu of a folder:
CAD drafting WORKING WITH STANDARD ELEMENTS 36
“Add Folder” – adds the folder to a dedicated subsidiary. If the command was run on the selected object, the folder will be added to the parent folder object.
“Save object in database as dwf block” – This utility allows you to save a single database of the drawings in format dwg, including standard items nanoCAD Mechanica23, design elements and primitives nanoCAD.
“Delete object” – This command deletes the selected object.
“Delete folder” – This command deletes the selected folder with all its contents.
“Rename” – The command allows you to rename an object (folder).
“Import object” – Adding to our previously exported file or folder object database DB.
To import a database from an external file, use the command “Import object” in the context menu invoked by a right-click on any folder or object in the section “Library” object manager. This will bring up a dialog box in which you specify the path to the file.
When importing compares the last modification date of the original (stored in the database) and the imported object. At concurrence of the imported content from content database objects will be updated only if they have more recent modification date.
If the command “Import object” was called for a standard lens, the outer fragment is imported to the folder containing the object.
CAD software WORKING WITH STANDARD ELEMENTS 37
“Export object” – Save the file to disk or folder object database DB.
To export any portion of the database you should use the command “Export object”. In the resulting dialog box, then you need to specify the path and file name for saving the captured designated section base.
Note:
Import operation into the database or export from the database can be made as separate objects, and entire folders with libraries of parts.
“Send by email” – It creates an e-mail with an attachment – Export objects.
CAD drawing WORKING WITH STANDARD ELEMENTS 38
“Copy” – Stored in a buffer object reference to paste a label on it.
“Paste shortcut” – Inserts a shortcut to a previously copied object
“Open with ScriptMaster” – Opens the object in the Object Wizard to edit.
“Add this folder palette” create a bookmark in the palette manager of the objects of the selected folder.
“Refresh” – Updating of the database (for example, after editing).
Tab “Objects”
Tab “Objects” object manager is a universal means of reviewing, monitoring, editing facilities nanoCAD Mechanica23, are on the drawing.
Places on this tab are grouped into sections – for example, standard parts, callout, bolted connections, etc. In order to navigate in the drawing the selected object is highlighted.
CAD drafting WORKING WITH STANDARD ELEMENTS 39
Toolbar
· CAD software WORKING WITH STANDARD ELEMENTS 40 Edit object.It calls the dialog for editing the selected object · CAD drawing WORKING WITH STANDARD ELEMENTS 41 Del object. Deletes the selected object · CAD drafting WORKING WITH STANDARD ELEMENTS 42Refresh. Updates the list of objects. The button is used when adding or removing objects from the drawing · CAD software WORKING WITH STANDARD ELEMENTS 43sQuick select. Search Tool nanoCAD Mechanica23 objects in the drawing on the set parameters, run the command “Quick Pick” · CAD drawing WORKING WITH STANDARD ELEMENTS 44Find and Replace. Open dialog boxFind and Replace.Context menu
In addition to the teams that are in the toolbar, the context menu of a selected object contains the following items depending on the selected object, and includes a team of repeating the context menu of the object on the drawing. Thus the tab “Objects” allows you to edit objects without having to search for them saturated drawing regardless of layer.
CAD drafting WORKING WITH STANDARD ELEMENTS 45
For example, for sub-database nanoCAD Mechanica23, further include items “Change representation”, “Bring to Front”, “Send to Back”, and “Change cover mode”.
Option “Hide” makes the selected object invisible in the drawing.
CAD software WORKING WITH STANDARD ELEMENTS 46Main menu: Mechanical – Standard objects – Standard parts library.
CAD drawing WORKING WITH STANDARD ELEMENTS 47Ribbon: Mechanical – Library – Standard parts library.
CAD drafting WORKING WITH STANDARD ELEMENTS 48Toolbar: “Standard objects”) – Standard parts library .
CAD software WORKING WITH STANDARD ELEMENTS 49Command line: MCSTD.
Inserting standard parts from the nanoCAD Mechanica 23 database is carried out using the database manager, which can be presented in full (dialog) form and in the form of a tool palette.
CAD drawing WORKING WITH STANDARD ELEMENTS 50
1. Select the insert object. 2. After selecting the object, specify the insertion point for the object. 3. Select the insertion direction (not all parts need to specify a direction vector). The dialog box for selecting object parameters will open. 4. Adjust the options in the dialog box.The standard dialog contains the following sections (sections are divided into tabs):
· Table parameters · Properties · Dependences · CalculationsImportant!
The composition of the sections (tabs of the insert dialog) is determined by the class of the part, its parameters and the environment of the insert.
The button CAD drafting WORKING WITH STANDARD ELEMENTS 51“Dynamic input” turns on the mode of visual definition of parameters when inserting.
CAD software WORKING WITH STANDARD ELEMENTS 52
As you move the mouse cursor, follow the change in the size of the object. LMB click to confirm the selection of the parameter value.
The “Apply” button allows you to apply the selected parameter values to the object without closing the dialog box. This deactivates the “Dynamic input” mode.
Important!
The description given here refers to the standard dialog for selecting parameters. Some objects of the nanoCAD Mechanica 23 base use special dialog boxes. In special dialog boxes, the location of the controls may vary.
Note:
If the path to the custom help is specified in the “Help” parameter of the standard part form, it will be called if the focus is on the form control. If the focus is on the “Cancel” or “OK” buttons, the help for standard items opens.
5. Click “OK” to complete the dialog.Toolbar Commands
· Add folder – Adds a folder at the specified location in the object tree. · Delete – Deletes the selected object or folder. · Edit note – Changes the name and note of the selected object.CAD drawing WORKING WITH STANDARD ELEMENTS 53
Context menu commands
· Import – Imports a base object. · Export – Exports a base object. · Send by email – Exports the object and sends it to the specified mail address. · Cut – Cuts an object, folder. · Paste – Inserts a previously cut object, folder. · Paste shortcut – Inserts a shortcut to a previously cut object, folder. · Add folder – Adds a folder at the specified location in the object tree. · Delete – Deletes the selected object or folder. · Edit note – Changes the name and note of the selected object. · Publish- Makes the object visible to other users of the network database. Objects can be published by administrators and editors (editors only their own objects). · Remove publish – Makes the object invisible to other users of the network database. Objects can be unpublished byadministrators and editors (editors only their own objects).Note:
The “Publish” and “Remove publish” commands are only available to editors and database administrators.
The table settings
On the “table settings” dialog insert standard parts displayed parameters responsible for the geometry of the object. These parameters correspond GOST’u (OST’u).
CAD drafting WORKING WITH STANDARD ELEMENTS 54
Properties
Properties of the parts that can be changed and described in the script are displayed on the “Properties”. On this tab located custom and reference parameters, switches species details and details of performances.
CAD software WORKING WITH STANDARD ELEMENTS 55
In the process of inserting parts “Glass” automatically set the relationship between the items “Bearing”, “End caps” and “Glass” (with parts falling into the aperture).
For items that have parameters available for manual entry or dynamically change tab “Properties” presents additional opportunities.
Consider the example of the detail “Glass” features interaction details.
CAD drawing WORKING WITH STANDARD ELEMENTS 56
The “Bearing diameter” – gray. This says that this option is not available for editing and dependence associated with the diameter of the bearing.
CAD drafting WORKING WITH STANDARD ELEMENTS 57
To enable editing of this option, you must go to the tab “Dependencies” and remove the dependency between the diameter of the items “Bearing” and an inner diameter of workpiece “glass.”.
CAD software WORKING WITH STANDARD ELEMENTS 58
Remove Dependency pressing the “Delete”
After this option is available for editing.
CAD drawing WORKING WITH STANDARD ELEMENTS 59
Dependences
The “Dependences” tab allows editing of dependences set automatically during the details allocation on the drawing, and dependences set with the “Dependences control dialog” .
Types of dependencies:
CAD drafting WORKING WITH STANDARD ELEMENTS 60
Parametric – settable parameter object equality arithmetic expression object parameters, which occurs accession.
CAD software WORKING WITH STANDARD ELEMENTS 61
CAD drawing WORKING WITH STANDARD ELEMENTS 62
Calculations
For rod attachment parts provided estimation during insertion. The result of the calculation is the recommended thread diameter for given loading conditions and strength class details.
For some types of rolling bearings estimation is also provided. The result of the calculation is the life of the bearing for the given loading conditions.
Reinsert object
CAD drafting WORKING WITH STANDARD ELEMENTS 63Main menu: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 64Reinsert object.
CAD drawing WORKING WITH STANDARD ELEMENTS 65Ribbon: Mechanical – Standard parts – CAD drafting WORKING WITH STANDARD ELEMENTS 66Reinsert object.
CAD software WORKING WITH STANDARD ELEMENTS 67Toolbar: CAD drawing WORKING WITH STANDARD ELEMENTS 68Reinsert object (on toolbar “Standard parts”).
CAD drafting WORKING WITH STANDARD ELEMENTS 69Command line: MCPICKPOINT.
Serves to re-insert the object in the drawing, combines editing commands properties and movement of item.
1. Click reinsert objectCAD software WORKING WITH STANDARD ELEMENTS 70. 2. Select the drawing or pasted object from the database. 3. Specify the new position of the object and insertion point. 4. Click OK.Markers, groups
User Groups
Working with groups in Construction 23 is performed using the following commands:
· Create custom groups · Inserting User GroupsCreate custom groups
CAD drawing WORKING WITH STANDARD ELEMENTS 71Main menu: Mechanical – Standard parts – Markers, Groups – CAD drafting WORKING WITH STANDARD ELEMENTS 72Group objects.
CAD software WORKING WITH STANDARD ELEMENTS 73Ribbon: Mechanical – Library – CAD drawing WORKING WITH STANDARD ELEMENTS 74Group objects.
CAD drafting WORKING WITH STANDARD ELEMENTS 75Toolbar: CAD software WORKING WITH STANDARD ELEMENTS 76Group objects ( “Standard parts”).
CAD drawing WORKING WITH STANDARD ELEMENTS 77Command line: MCGROUPOBJECTS.
Constraints describing the interaction of two or more objects, It is advisable to store these in the objects database in a related group. Group nanoCAD Mechanica 23 has the following features:
· Group is stored in the object database, has a pattern preview before pasting. · Components of the group in addition to objects nanoCAD Mechanica 23 can be primitives and blocks in nanoCAD. · Group may be transferred as part of the database file to other users. · Group may have additional dependencies with other groups and objects. · Components of the group remain together parametric dependence. · Components in the group can be specified both individually and in groups.Thus, the group is a powerful way of organizing and structuring graphics data in a separate local file drawing document.
Create a Group
Button CAD drafting WORKING WITH STANDARD ELEMENTS 78Group objects
Gather and create database objects in the design position in the drawing. On the toolbar, Library objects,click Group objects.
Select the required objects in the drawing AutoCAD specify the origin of the group.
In the dialog box New group on the left side is a list of objects in the group. Name objects in the list is taken from the string value for the specifications set in the properties of objects.
Button CAD software WORKING WITH STANDARD ELEMENTS 79Highlight group objects highlights and centers on the screen objects in the group.
Button CAD drawing WORKING WITH STANDARD ELEMENTS 80Set parameter table. Opens the editor table settings. Table of parameters used to select the group attribute values from a predefined list of values.
Button CAD drafting WORKING WITH STANDARD ELEMENTS 81Show form editor. Opens Form Editor to create a special dialog box.
ButtonCAD software WORKING WITH STANDARD ELEMENTS 82save changes to database. Saves the base group Construction Site 23.
In the right part of the window picture preview and a list of attributes for the group.
Editing attributes produced in the cells of the table.
CAD drawing WORKING WITH STANDARD ELEMENTS 83
Adding attributes produced from the parameter list of objects in the group.
Expand the selected entry in the list (with the “+” next to the name of the object) and double click on the parameter, add an attribute in the table.
You can install a bidirectional relationship between the group and attribute parameter object that is associated with this attribute. The list of attributes in the column Attribute Properties , click the left mouse button on the icon CAD drafting WORKING WITH STANDARD ELEMENTS 84. Depending on the mode change bidirectional, it will indicate the icon CAD software WORKING WITH STANDARD ELEMENTS 85. Thus, when the value of the attribute group, and the parameter of the object is changed.
Save the group of objects in the database by pressing the buttonCAD drawing WORKING WITH STANDARD ELEMENTS 86save changes to database. Choose a location and name for the group (the default group name matches the specified value attribute Group Name). Click OK.
Group created and saved to the database. Now you can insert multiple grouped objects in a drawing, resizing and positioning of objects, while preserving established parametric and geometric constraints.
Important!
Group objects only retains information about dependencies between objects and attributes set. For insertion to be carried out correctly, you must have a database of all the objects in this group.
When working with a group of attributes of the various available methods for selecting values. In the context menu of the column Properties attribute in the attribute list, select:
CAD drafting WORKING WITH STANDARD ELEMENTS 87 · Add property from object – allows you to set the attribute value by linking it with an attribute value of another object in the drawing. · Set to unique string – allows you to set the attribute-counter, which will increase its value by 1 for each subsequent inserted marker. In the Value column for the visible attribute counter must specify a character string – prefix. The drawing will be appended to the prefix value of the counter. · Set to calculated field – allows you to set the attribute value using a mathematical expression, using references to other attributes of the marker and mathematical functions. In reference to another attribute marker use the name of the attribute recorded in braces. · Automatically increment – allows you to set the attribute-counter, which will increase its value to 1, compared with the same attribute of the previous insertion marker. This attribute allows the counter-repetition of identical values for several markers that distinguishes it from the attribute set to a unique value. · Set to simple field – sets the attribute type by default.Insert group
Insert group may be carried out as the object manager , and with a tool insert group.
Button CAD software WORKING WITH STANDARD ELEMENTS 88Insert Group toolbar Library objects opens a dialog Box group.
In the list of the group and press OK. If you insert a group of objects , you must specify the insertion point of the group. If you insert a group of dependencies , you need to select the drawing objects that you want to associate with the dependencies.
In the dialog box Insert group commands are available:
CAD drawing WORKING WITH STANDARD ELEMENTS 89Create group. Creates a new group.
CAD drafting WORKING WITH STANDARD ELEMENTS 90Delete group. Deletes the selected group from the database.
CAD software WORKING WITH STANDARD ELEMENTS 91Select items from the drawing for the group. Used to edit an existing or new group.
CAD drawing WORKING WITH STANDARD ELEMENTS 92Detail groups. Opens a list of groups of items.
CAD drafting WORKING WITH STANDARD ELEMENTS 93Dependence group. Opens a list of groups dependencies.
Switch multiple . Enables insertion of multiple groups in the drawing.
Switch Add group marker. If installed, together with a group of drawing a marker is added to the group.
Marker group is designed for group editing and data to other objects in the drawing (see Binding arbitrary graphical and tabular data ).
CAD software WORKING WITH STANDARD ELEMENTS 94
Editing a Group
After you insert a group of objects in the drawing, or when the command to edit the marker group opens the edit dialog group.
CAD drawing WORKING WITH STANDARD ELEMENTS 95Highlight group objects. Highlights and centers on the screen objects in the group.
CAD drafting WORKING WITH STANDARD ELEMENTS 96Edit marker Properties. Includes editing mode, where you can change the set of objects in the group, add or remove attributes.
CAD software WORKING WITH STANDARD ELEMENTS 97Object tree. Enables and disables the object tree in the left pane.
CAD drawing WORKING WITH STANDARD ELEMENTS 98Set parameters table. This button is available if the group contains a table of parameters. In the dialog box, select the row attribute values, and click OK.
Group dependencies
Group dependencies remain parametric description and assembly relationships between objects. When you insert such groups they are not added to the drawing objects, but only established the relationship between existing objects.
Consider creating and maintaining relationships between the two cuffs.
Important!
Before you create a group, you must place the drawing objects to be included in the group and set the dependencies between objects.
Insert the base of the two objects Cuff GOST 8752-79. Set between the geometric co-directional dependence Combining axis and the plane at a distance obj.B (see Constraints between two objects ) and the parametric dependence of the outer diameter.
CAD drafting WORKING WITH STANDARD ELEMENTS 99
Select Insert group. CAD software WORKING WITH STANDARD ELEMENTS 100
In the dialog box, click Dependence groups.
CAD drawing WORKING WITH STANDARD ELEMENTS 101
Button CAD drafting WORKING WITH STANDARD ELEMENTS 102 Creates group. In the groups list, change the name of the new group (eg, “Package cuffs”). To edit, click the left mouse button on the name of the group.
CAD software WORKING WITH STANDARD ELEMENTS 103
Click CAD drawing WORKING WITH STANDARD ELEMENTS 104Select group details from drawing and select the drawing both cuffs. Press Enter.
In the dialog box, select the dependent listed in the list established between objects. Click OK.
CAD drafting WORKING WITH STANDARD ELEMENTS 105
Look at the result of the creation of group dependencies.
CAD software WORKING WITH STANDARD ELEMENTS 106
In the description of the group under the picture preview Set the selection order when inserting objects group dependencies.
Group dependencies are stored in the database automatically. Click Cancel to complete the group.
Insert a drawing of the base of the cuff, which must be applied to create a dependency.
CAD drawing WORKING WITH STANDARD ELEMENTS 107
Select Insert group , click Group Dependency . In the list of dependence “ Package cuffs. “ Click OK.
CAD drafting WORKING WITH STANDARD ELEMENTS 108
Select the drawing cuffs to be connected sequentially (in the example need to perform steps 10-11 twice).
CAD software WORKING WITH STANDARD ELEMENTS 109
Automatically set dependence stored in the description of the group.
Inserting Groups
CAD drawing WORKING WITH STANDARD ELEMENTS 110Main menu: Mechanical – Standard parts – Markers, Groups – CAD drafting WORKING WITH STANDARD ELEMENTS 111Insert group.
CAD software WORKING WITH STANDARD ELEMENTS 112Ribbon: Mechanical – Library – CAD drawing WORKING WITH STANDARD ELEMENTS 113Insert group.
CAD drafting WORKING WITH STANDARD ELEMENTS 114Toolbar: CAD software WORKING WITH STANDARD ELEMENTS 115Insert group ( “Standard parts”).
CAD drawing WORKING WITH STANDARD ELEMENTS 116Command line: MCINSERTGROUP.
CAD drafting WORKING WITH STANDARD ELEMENTS 117Library: Groups.
Command Options
Insert group Box lets you create a set of objects with superimposed parametric and geometric constraints.
CAD software WORKING WITH STANDARD ELEMENTS 118
CAD drawing WORKING WITH STANDARD ELEMENTS 119Create group
CAD drafting WORKING WITH STANDARD ELEMENTS 120Deleting Group
CAD software WORKING WITH STANDARD ELEMENTS 121Select group details from drawing
CAD drawing WORKING WITH STANDARD ELEMENTS 122CAD drafting WORKING WITH STANDARD ELEMENTS 123 Switch between groups of objects and dependencies
The mechanism used in the team group insert , you can insert a group of objects
CAD software WORKING WITH STANDARD ELEMENTS 124
The “Add marker group” enables the group a graphic element – a marker located at the insertion point of the group. In marker may include parameters of individual parts group that can help you when pasting automatically change the geometry of the group of related components.
“Multiple insert” allows you to create multiple copies of the selected group.
If a user group has been maintained by the standard in the folder $\MCS\Groups, then insert it in the tree by choosing the object manager.
If a group is defined form, then insert dialogue is as follows:
CAD drawing WORKING WITH STANDARD ELEMENTS 125
· The dialog box includes a tree of groups – a list of objects and their parameters group. This tree can disable button CAD drafting WORKING WITH STANDARD ELEMENTS 126 · The preview window group · Form input values groupWhen you click on CAD software WORKING WITH STANDARD ELEMENTS 127 you can switch to edit mode group settings.
Universal marker
CAD drawing WORKING WITH STANDARD ELEMENTS 128Main menu: Mechanical – Standard objects – Markers, groups – CAD drafting WORKING WITH STANDARD ELEMENTS 129Add marker.
CAD software WORKING WITH STANDARD ELEMENTS 130Ribbon: Mechanical – Library – CAD drawing WORKING WITH STANDARD ELEMENTS 131Add marker.
CAD drafting WORKING WITH STANDARD ELEMENTS 132Toolbar: “Standard objects”- CAD software WORKING WITH STANDARD ELEMENTS 133Add marker.
CAD drawing WORKING WITH STANDARD ELEMENTS 134Command line: MCCREATEUMARKER.
The “Marker” tool is designed specifically to create a connection between an arbitrary graphic object (primitive) nanoCAD and a spreadsheet-specification. A universal marker is a translator of data from drawing objects into the nanoCAD Mechanica 23table by means of special means – marker attributes.
Marker attributes can be visible or hidden. The values of the visible attributes are displayed in the drawing as text strings.
The marker, as an object nanoCAD Mechanica 23, can be saved in the object library and used repeatedly. The marker can also be included in the groups of objects nanoCAD Mechanica 23, providing the ability to specify the entire functional groups.
Create marker
Let’s consider creating a marker in the form of a positional leader.
1. Set the required current scale. 2. Insert two text lines into the drawing and draw a horizontal line between them.CAD drafting WORKING WITH STANDARD ELEMENTS 135
These objects will form a leader shelf template with two text labels. To use text strings as marker attributes, the first character must be “$”.
3. Call the command CAD software WORKING WITH STANDARD ELEMENTS 136“Add marker”, use a box or crossing box to select the objects that made up the marker.CAD drawing WORKING WITH STANDARD ELEMENTS 137
4. Snap the base point of the marker.CAD drafting WORKING WITH STANDARD ELEMENTS 138
5. The “Creation of a marker” dialog box appears. The properties table will list the attributes entered in the callout text boxes:CAD software WORKING WITH STANDARD ELEMENTS 139
Column “Name” contains the working name of the attribute.
Column “Description” describes the attribute.
In column “Value” the values of the attribute are entered. Values can be either numeric or text. Auxiliary commands are available in the context menu of the “Value” column.
CAD drawing WORKING WITH STANDARD ELEMENTS 140
Column “Attribute property” is used to indicate the type of the input attribute. Various attribute labels are provided to indicate their type. The default is “Set to simple field”.
CAD drafting WORKING WITH STANDARD ELEMENTS 141
Attribute types:
· Add property from object- allows you to set an attribute value by associating it with the attribute value of another object in the drawing.Important!
An object is understood as an object from the base of standard products.
After choosing the type, it is suggested to select the object and the object attribute.
CAD software WORKING WITH STANDARD ELEMENTS 142
After selecting an attribute, its value falls into the “Value” column, and in the “Attribute property” column the name of the selected attribute.
CAD drawing WORKING WITH STANDARD ELEMENTS 143
After assigning an attribute, you can change the type of relationship with an object attribute:
CAD drafting WORKING WITH STANDARD ELEMENTS 144One-way communication – changing the value in an attribute of an object affects the value of the marker.
CAD software WORKING WITH STANDARD ELEMENTS 145Two way communication – changing the value in the marker affects the attribute of the object, and vice versa.
CAD drawing WORKING WITH STANDARD ELEMENTS 146Basic communication – an attribute of an object can only be changed from a marker. If the attribute is a table value in a basic relationship, the closest value from the table is displayed. The entered value will be displayed in brackets.
· Set To Unique string – allows you to set a counter attribute that will increase its value by 1 for each subsequent inserted marker. In the “Value” column for the visible counter attribute, you can specify a character string – a prefix. In the drawing, the counter value will be appended to the prefix.CAD drafting WORKING WITH STANDARD ELEMENTS 147
CAD software WORKING WITH STANDARD ELEMENTS 148
· Set to calculated field- allows you to set the value of an attribute using a mathematical expression, using references to other marker attributes, operators, and mathematical functions. The name of the desired attribute is used as a reference to another marker attribute.Note:
Computed attributes are defined and calculated from top to bottom.
Important!
Calculations are performed in curly braces.
Function:
CAD drawing WORKING WITH STANDARD ELEMENTS 149
Result:
CAD drafting WORKING WITH STANDARD ELEMENTS 150
· Automatically increment – allows you to set a counter attribute that will increase its value by 1 compared to the same attribute of the previous inserted marker. Such a counter attribute allows repetition of the same values for several markers, which distinguishes it from an attribute set to a unique value.CAD software WORKING WITH STANDARD ELEMENTS 151
CAD drawing WORKING WITH STANDARD ELEMENTS 152
· Set to simple field – sets the default attribute type to plain text.Note:
Attributes included in the block can be included in the marker attribute table nanoCAD!
6. Edit the marker using the marker controls at the bottom of the dialog box.CAD drafting WORKING WITH STANDARD ELEMENTS 153
Include:
· “Marker draw mode”. When you click on this button, a drop-down list of rendering modes appears: · CAD software WORKING WITH STANDARD ELEMENTS 154Simple marker. · CAD drawing WORKING WITH STANDARD ELEMENTS 155Draw position line. · CAD drafting WORKING WITH STANDARD ELEMENTS 156Linear align.When you select the display method with the addition of a leader line, an additional button CAD software WORKING WITH STANDARD ELEMENTS 157“Arrow Type” appears to select the type of arrow:
CAD drawing WORKING WITH STANDARD ELEMENTS 158
Click this button and select the desired extension line arrow type.
Arrow display parameters are defined in the “Settings – Symbols – Extension – Additional extension lines” settings.
· CAD drafting WORKING WITH STANDARD ELEMENTS 159“Unploted”. When this button is enabled, the marker is placed on a special layer that is not displayed when printing. When this mode is activated, the icon on the (CAD software WORKING WITH STANDARD ELEMENTS 160) button changes and the marker is displayed in gray on the screen (in accordance with the color of the non-printed layer). · CAD drawing WORKING WITH STANDARD ELEMENTS 161“Show form editor”- calls the custom form editor to create a dialog for working with marker attributes.The following commands are available in the drop-down menu:
“Edit Form”. Open Form Editor.
“Add Form. Adds additional forms, while the marker can change the appearance of the form, by condition or by the user’s choice. By default, the marker has one form.
CAD drafting WORKING WITH STANDARD ELEMENTS 162
The form editor uses standard Windows form generation technology. The toolkit consists of three blocks – the graphic editor area, the toolbar with form objects and the properties window of the inserted elements. For inserted fields, the “Field Name” (“Variable”) can be selected from the list of existing marker description fields. In this case, the default field value is equal to the field value in the marker description.
When adding a second form, you are prompted to enter a name for the form. The variable Tag – mcFormName is added to the properties table. This variable is responsible for the name of the form, it can be set in a calculated field and, for example, made equal to execution. Empty or “Main” is considered the main form.
CAD software WORKING WITH STANDARD ELEMENTS 163
· CAD drawing WORKING WITH STANDARD ELEMENTS 164“Geometry”. Used to change the appearance of the generic marker and define the insertion point.The following commands are available in the drop-down menu:
Get new geometry. The button is used to change the appearance of the universal marker and define the insertion point.
Export marker source graphics. Exports marker geometry to a file.
Add Implemetnation. Adds additional performances, while the marker can change its appearance, by condition or by the user’s choice.When creating a new implementation, you are prompted to enter its name. When adding implementation, the Tag – mcImplementation variable is added to the properties table. This variable is responsible for the name of the current marker implementation. It can be set to a calculated field or linked to a list on a form. Empty or “Main” is considered the main implementation.
CAD drafting WORKING WITH STANDARD ELEMENTS 165
· CAD software WORKING WITH STANDARD ELEMENTS 166“Set parameters table”. Opens the marker parameter table editor. When inserting a marker and having a table of values, it is possible to assign a group of values to the marker attributes.CAD drawing WORKING WITH STANDARD ELEMENTS 167
In the list, select the parameters whose values will be selected from the table. In the right part of the window, enter the required number of lines with values. Close the dialog with the “OK” button.
· CAD drafting WORKING WITH STANDARD ELEMENTS 168Save changes to odatabase. The button is intended for writing a marker to library nanoCAD Mechanica 23. · CAD software WORKING WITH STANDARD ELEMENTS 169Apply changes to all markers of this types. Applies changes to all markers of this type in the drawing. Serves for changing the marker template for all markers made according to this template and inserted into the drawing. 7. If necessary, add any number of hidden attributes, filling in the rows of the table in sequence. The attribute is added in the bottom line of the table, marked with an “*” symbol. 8. For future use of the marker, save it to the database as a named object.CAD drawing WORKING WITH STANDARD ELEMENTS 170
In the “Create element” dialog box, specify the path to save, the name of the object and the note (for more information on working with the object base, see the nanoCAD Mechanica 23Object Manager). After you save the marker, a message appears prompting you to update the existing copies of the marker in the drawing.
9. nanoCAD Mechanica 23 makes it possible to immediately apply the created marker. The command line prompts you to install the generated token. Pick an insertion point in the drawing. Identical markers can be simply copied in the future. In other cases, the marker is inserted directly from the base.CAD drafting WORKING WITH STANDARD ELEMENTS 171
Edit marker
Editing of a marker is carried out in a dialog box, the title of which corresponds to the name of the marker. For example, when you call for editing the “Position_Marker” marker, the creation of which was described in the previous paragraph, the dialog box will look like this:
CAD software WORKING WITH STANDARD ELEMENTS 172
Additional commands are located at the bottom of the window:
· “Marker draw mode”. When you click on this button, a drop-down list of rendering modes appears: · CAD drawing WORKING WITH STANDARD ELEMENTS 173Simple marker. · CAD drafting WORKING WITH STANDARD ELEMENTS 174Draw position line. · CAD software WORKING WITH STANDARD ELEMENTS 175Linear align.When you select the display method with the addition of a leader line, an additional button CAD drawing WORKING WITH STANDARD ELEMENTS 176“Arrow Type” appears to select the type of arrow:
CAD drafting WORKING WITH STANDARD ELEMENTS 177
· CAD software WORKING WITH STANDARD ELEMENTS 178 “Unploted”. When this button is enabled, the marker is placed on a special layer that is not displayed when printing. When this mode is activated, the icon on the (CAD drawing WORKING WITH STANDARD ELEMENTS 179) button changes and the marker is displayed in gray on the screen (in accordance with the color of the non-printed layer). · CAD drafting WORKING WITH STANDARD ELEMENTS 180“Highlight info source object”. Highlights in the drawing the object with which the marker is associated (The function is available if the “Add property from object” mode is set for one or several attributes and the corresponding object was specified when inserting the marker). · CAD software WORKING WITH STANDARD ELEMENTS 181“Edit marker properties”. Turns on the edit mode, in which you can change the appearance of the marker, add or remove attributes.System variables in marker
mcImplementation – Execution management. Empty or “Main” means the main view.
mcFormName – Form management. Empty or “Main” means the main form.
mcArrowSize – Arrow size control.
mcDefLayer – Controls the marker location layer. The “Value” field contains the name of the layer.
mcShowFormOnInsert – Controls the display of the dialog when inserting. If the value is 0, the dialog is not shown when inserting. The value can be calculated.
Template Wizard
CAD drawing WORKING WITH STANDARD ELEMENTS 182Main menu: Mechanical – Standard parts – Markers, Groups – CAD drafting WORKING WITH STANDARD ELEMENTS 183Template wizard.
CAD software WORKING WITH STANDARD ELEMENTS 184Ribbon: Mechanical – Library – CAD drawing WORKING WITH STANDARD ELEMENTS 185Template wizard.
CAD drafting WORKING WITH STANDARD ELEMENTS 186Toolbar: CAD software WORKING WITH STANDARD ELEMENTS 187Template wizard ( “Standard parts”).
CAD drawing WORKING WITH STANDARD ELEMENTS 188Command line: MCTWIZ.
Template Wizard is designed to create easy to use tools of commonly used design elements drawing.
Basic rules
When the command will be asked to select an object to create a template. If the object was preselected, then immediately start dialogue Template Wizard.
CAD drafting WORKING WITH STANDARD ELEMENTS 189
Command Options
Button Create template – creates a template in the database or applies the changes made in the editor.
Button From – Starts the form template.
Button CAD software WORKING WITH STANDARD ELEMENTS 190Create a new template – Creates a new template in the database based on the selected graphics and created form.
Button CAD drawing WORKING WITH STANDARD ELEMENTS 191Delete form – deletes the created form template.
Example of creating a template
Consider the example of creating a template signs of roughness. To do this, the drawing shall bear one designation:
CAD drafting WORKING WITH STANDARD ELEMENTS 192
After you run the Wizard Templates chosen designation roughness.
To work with the template you must save it in the database that will be invited to do by pressing the button CAD software WORKING WITH STANDARD ELEMENTS 193.
CAD drawing WORKING WITH STANDARD ELEMENTS 194
Then click on the Create a form and create a form using the notation tools online forms.
For example, we can take two parameters – the first line designations and direction of irregularities. Both parameters are added to the form as a combo box (drag while holding Ctrl).
CAD drafting WORKING WITH STANDARD ELEMENTS 195 > CAD software WORKING WITH STANDARD ELEMENTS 196
After editing, we obtain the form of the following form:
CAD drawing WORKING WITH STANDARD ELEMENTS 197
Close the form editor, click to update in template.
CAD drafting WORKING WITH STANDARD ELEMENTS 198
Template will be saved in the database and will be displayed in the object manager.
CAD software WORKING WITH STANDARD ELEMENTS 199
Now when you insert from the database will be able to also place the designation of roughness on the shelf line-outs, but when you edit your form will appear:
CAD drawing WORKING WITH STANDARD ELEMENTS 200
Editing blocks nanoCAD
If the original graphics selected block nanoCAD, its attributes are also displayed in the form editor as available variables.
CAD drafting WORKING WITH STANDARD ELEMENTS 201 > CAD software WORKING WITH STANDARD ELEMENTS 202
When creating a form in the database and maintaining such a block is inserted into the drawing as a block of the same source, only the attributes can be set up via a custom form.
CAD drawing WORKING WITH STANDARD ELEMENTS 203
Control overlapping objects
Change hidden mode
CAD drafting WORKING WITH STANDARD ELEMENTS 204Main menu: Mechanical – Standard parts- Cover – CAD software WORKING WITH STANDARD ELEMENTS 205Change hidden mode.
CAD drawing WORKING WITH STANDARD ELEMENTS 206Toolbar: “Standard parts” – CAD drafting WORKING WITH STANDARD ELEMENTS 207Change hidden mode.
CAD software WORKING WITH STANDARD ELEMENTS 208Command line: MCCHCOVER.
The command switches the display mode of hidden lines.
nanoCAD Mechanica 23 allows you to hide individual graphics elements. The overlapping nature of the base object or user block is determined by a special parameter – the overlap level ZOrder. ZOrder – this is a numeric parameter whose value determines the overlap priority. An object with a large ZOrder value overrides an object with a lower value.
Primitives nanoCAD have the lowest overlapping level and therefore are always overlapped by objects from the database. That at an insertion of object nanoCAD Mechanica 23 objects nanoCAD did not overlap, it is necessary to disable the switch in the object insert dialog “Cover primitives”:
CAD drawing WORKING WITH STANDARD ELEMENTS 209
The area in the drawing that the base object covers nanoCAD Mechanica 23, is called “Contour of suppression”. An overlap exists within this contour.
1. Call command.CAD drafting WORKING WITH STANDARD ELEMENTS 210
2. In the context menu, select the desired view of the overlapped objects “Normal”, “Dotted” or “Switch”.Normal
Dotted
Switch
CAD software WORKING WITH STANDARD ELEMENTS 211
CAD drawing WORKING WITH STANDARD ELEMENTS 212
The command appends the value. Those. If a normal overlap has been established, then the dashed line becomes, and vice versa.
3. Select the secant frame for the objects for which you want to change the overlapping mode. 4. Repeat if necessary items 2 and 3, or complete the command on the key “Enter”.Regenerate suppression contours
CAD drafting WORKING WITH STANDARD ELEMENTS 213Main menu: Mechanical – Standard parts – Cover – CAD software WORKING WITH STANDARD ELEMENTS 214Regenerate suppression contours.
CAD drawing WORKING WITH STANDARD ELEMENTS 215Toolbar: “Standard parts” – CAD drafting WORKING WITH STANDARD ELEMENTS 216Regenerate suppression contours.
CAD software WORKING WITH STANDARD ELEMENTS 217Command line: MCCOVER.
Regenerate the drawing and redraw the contents of the current viewport.
Before
After
CAD drawing WORKING WITH STANDARD ELEMENTS 218
CAD drafting WORKING WITH STANDARD ELEMENTS 219
Move up
CAD software WORKING WITH STANDARD ELEMENTS 220Main menu: Mechanical – Standard parts – Cover – CAD drawing WORKING WITH STANDARD ELEMENTS 221Move up.
CAD drafting WORKING WITH STANDARD ELEMENTS 222Toolbar: “Standard parts” – CAD software WORKING WITH STANDARD ELEMENTS 223Move up.
CAD drawing WORKING WITH STANDARD ELEMENTS 224Command line: MCMOVEUP.
1. Call command;CAD drafting WORKING WITH STANDARD ELEMENTS 225
2. Select the objects you want to move up;CAD software WORKING WITH STANDARD ELEMENTS 226
3. Select the objects to be compared;CAD drawing WORKING WITH STANDARD ELEMENTS 227
4. After the selection is complete, the objects that need to be moved up will automatically increase the overlap level (ZOrder).CAD drafting WORKING WITH STANDARD ELEMENTS 228
Move down
CAD software WORKING WITH STANDARD ELEMENTS 229Main menu: Mechanical – Standard parts – Cover – CAD drawing WORKING WITH STANDARD ELEMENTS 230Move down.
CAD drafting WORKING WITH STANDARD ELEMENTS 231Toolbar: “Standard parts” – CAD software WORKING WITH STANDARD ELEMENTS 232Move down.
CAD drawing WORKING WITH STANDARD ELEMENTS 233Command line: MCMOVEDOWN.
1. Call command;CAD drafting WORKING WITH STANDARD ELEMENTS 234
2. Select the objects you want to move down;CAD software WORKING WITH STANDARD ELEMENTS 235
3. Select objects to be compared;CAD drawing WORKING WITH STANDARD ELEMENTS 236
4. After the selection is complete, the objects that are to be moved down will automatically decrease the overlap level (ZOrder).CAD drafting WORKING WITH STANDARD ELEMENTS 237
Part trim
Add part trim
CAD software WORKING WITH STANDARD ELEMENTS 238Main menu: Mechanical – Standard objects – Part Contour Trim – CAD drawing WORKING WITH STANDARD ELEMENTS 239Add part trim.
CAD drafting WORKING WITH STANDARD ELEMENTS 240Ribbon: Mechanical – Library – CAD software WORKING WITH STANDARD ELEMENTS 241Add part trim.
CAD drawing WORKING WITH STANDARD ELEMENTS 242Toolbar: “Standard objects”- CAD drafting WORKING WITH STANDARD ELEMENTS 243Add part trim.
CAD software WORKING WITH STANDARD ELEMENTS 244Command line: MCTRIM.
The command allows you to trim objects of metal structures.
Trimming with contour indication
1. Call the command CAD drawing WORKING WITH STANDARD ELEMENTS 245“Add part trim”.
2. Pick an outline. A contour can be a line segment, circle, arc, polyline (closed and open).
CAD drafting WORKING WITH STANDARD ELEMENTS 246
3. Specify trimming objects.
If a circle or closed polyline is used as a path, the trimming object is selected within the path.
CAD software WORKING WITH STANDARD ELEMENTS 247CAD drawing WORKING WITH STANDARD ELEMENTS 248
If a linear path is used, the trimming object is selected from one side of the path.
CAD drafting WORKING WITH STANDARD ELEMENTS 249CAD software WORKING WITH STANDARD ELEMENTS 250
4. Press the “Esc” button to end trimming. The object will be trimmed.
CAD drawing WORKING WITH STANDARD ELEMENTS 251
Trimming mode “COntour”
1. Call the command CAD drafting WORKING WITH STANDARD ELEMENTS 252“Add part trim”.
2. Select trim mode “COntour”.
3. Draw a closed polyline path.
CAD software WORKING WITH STANDARD ELEMENTS 253
4. Pick a trimming object within the path.
CAD drawing WORKING WITH STANDARD ELEMENTS 254
5. Trimming an object is made.
CAD drafting WORKING WITH STANDARD ELEMENTS 255
Trimming mode “rectangle by tWO points”
1. Call the command CAD software WORKING WITH STANDARD ELEMENTS 256“Add part trim”.
2. Select trim mode “rectangle by tWO points”.
3. Pick the first corner.
CAD drawing WORKING WITH STANDARD ELEMENTS 257
4. Pick the second corner.
CAD drafting WORKING WITH STANDARD ELEMENTS 258
5. Pick a trimming object inside the rectangle.
CAD software WORKING WITH STANDARD ELEMENTS 259
6. Trimming an object is made.
CAD drawing WORKING WITH STANDARD ELEMENTS 260
Trimming mode “rectangle by thrEE points”
Allows for trimming at the desired angle.
1. Call the command CAD drafting WORKING WITH STANDARD ELEMENTS 261“Add part trim”.
2. Select trim mode “rectangle by thrEE points”.
3. Pick the first point.
CAD software WORKING WITH STANDARD ELEMENTS 262
4. Pick the second point.
CAD drawing WORKING WITH STANDARD ELEMENTS 263
5. Pick the size of the outline.
CAD drafting WORKING WITH STANDARD ELEMENTS 264
6. Pick a trimming object inside the rectangle.
CAD software WORKING WITH STANDARD ELEMENTS 265
7. Trimming an object is made.
CAD drawing WORKING WITH STANDARD ELEMENTS 266
Trimming mode “HOle”
1. Call the command CAD drafting WORKING WITH STANDARD ELEMENTS 267“Add part trim”.
2. Select trim mode “HOle”.
3. Pick the center of the hole.
CAD software WORKING WITH STANDARD ELEMENTS 268
4. Pick a radius for the hole.
CAD drawing WORKING WITH STANDARD ELEMENTS 269
5. Pick a trimming object inside the circle.
CAD drafting WORKING WITH STANDARD ELEMENTS 270
CAD software WORKING WITH STANDARD ELEMENTS 271
Remove part trim
CAD drawing WORKING WITH STANDARD ELEMENTS 272Main menu: Mechanical – Standard parts – Part Contour Trim – CAD drafting WORKING WITH STANDARD ELEMENTS 273Remove part trim.
CAD software WORKING WITH STANDARD ELEMENTS 274Ribbon: Mechanical – Library – CAD drawing WORKING WITH STANDARD ELEMENTS 275Remove part trim.
CAD drafting WORKING WITH STANDARD ELEMENTS 276Toolbar: “Standard parts” – CAD software WORKING WITH STANDARD ELEMENTS 277Remove part trim.
CAD drawing WORKING WITH STANDARD ELEMENTS 278Command line: MCTRIMDELETE.
The command removes a previously created trim.
1. Call the command CAD drafting WORKING WITH STANDARD ELEMENTS 279“Remove part trim”.
CAD software WORKING WITH STANDARD ELEMENTS 280
2. Specify the objects you want to reset and press “Enter” (or press “Spacebar”) to select all objects.
CAD drawing WORKING WITH STANDARD ELEMENTS 281
3. The specified objects will be restored to their original state.
CAD drafting WORKING WITH STANDARD ELEMENTS 282
Add View
CAD software WORKING WITH STANDARD ELEMENTS 283Main menu: Mechanical – Standard parts – CAD drawing WORKING WITH STANDARD ELEMENTS 284Add view.
CAD drafting WORKING WITH STANDARD ELEMENTS 285Ribbon: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 286Add view.
CAD drawing WORKING WITH STANDARD ELEMENTS 287Toolbar: CAD drafting WORKING WITH STANDARD ELEMENTS 288Add view (on toolbar “Standard parts”).
CAD software WORKING WITH STANDARD ELEMENTS 289Context menu: CAD drawing WORKING WITH STANDARD ELEMENTS 290Add view (on select object).
CAD drafting WORKING WITH STANDARD ELEMENTS 291Command line: MCADDVIEW.
Designed to quickly add a new type of projection from the base of the inserted object to the drawing.
· Select the object to copy. · Specify the insertion point of the object. Context menu commands Front / left / right / top / bottom standard projection (to insert a particular projection, it is necessary that it be recognized in the object). · Context menu commands Point, Angle mode selection switch, respectively the insertion point or selection mode direction. · Complete the cyclic command.Adding a projection view to the object database can be done using the Add View from the context menu for the selected object.
Simplified / Full View
CAD software WORKING WITH STANDARD ELEMENTS 292Main menu: Mechanical – Standard parts – CAD drawing WORKING WITH STANDARD ELEMENTS 293Change representation.
CAD drafting WORKING WITH STANDARD ELEMENTS 294Ribbon: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 295Change representation.
CAD drawing WORKING WITH STANDARD ELEMENTS 296Toolbar: CAD drafting WORKING WITH STANDARD ELEMENTS 297Change representation (on toolbar “Standard parts”).
CAD software WORKING WITH STANDARD ELEMENTS 298Context menu: CAD drawing WORKING WITH STANDARD ELEMENTS 299Change representation (on select object).
CAD drafting WORKING WITH STANDARD ELEMENTS 300Command line: MCCHANGEREPRESENT.
· Press the button and select the database object in the drawing. · Context menu commands Full, Simplified select the object representation.Switching presentation can be accomplished by using the Change view from the context menu for the selected object.
Mirror Part
CAD software WORKING WITH STANDARD ELEMENTS 301Main menu: Mechanical – Standard parts – CAD drawing WORKING WITH STANDARD ELEMENTS 302Mirrow part.
CAD drafting WORKING WITH STANDARD ELEMENTS 303Ribbon: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 304Mirrow part.
CAD drawing WORKING WITH STANDARD ELEMENTS 305Toolbar: CAD drafting WORKING WITH STANDARD ELEMENTS 306Mirrow part (on toolbar “Standard parts”).
CAD software WORKING WITH STANDARD ELEMENTS 307Command line: MCMIRROWSTD.
· Press the button and select the database object in the drawing. · Press Enter.Occur along the axis of revolution object X.
Regenerate STD parts
CAD drawing WORKING WITH STANDARD ELEMENTS 308Main menu: Mechanical – Standard parts – CAD drafting WORKING WITH STANDARD ELEMENTS 309Regenerate Std Parts.
CAD software WORKING WITH STANDARD ELEMENTS 310Toolbar: CAD drawing WORKING WITH STANDARD ELEMENTS 311Regenerate Std Parts (on toolbar “Standard parts”).
CAD drafting WORKING WITH STANDARD ELEMENTS 312Command line: MCREGENSTD.
The team needed to upgrade the graphics part of the object (s).
Operation
1. Call the command “Regenerate STD parts” 2. Specify the objects that you need to update or Enter, if you need to update all of the objects. 3. These objects will be updatedUser defined object
CAD software WORKING WITH STANDARD ELEMENTS 313Main menu: Mechanical – Standard parts – CAD drawing WORKING WITH STANDARD ELEMENTS 314User defined object.
CAD drafting WORKING WITH STANDARD ELEMENTS 315Ribbon: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 316User defined object.
CAD drawing WORKING WITH STANDARD ELEMENTS 317Toolbar: CAD drafting WORKING WITH STANDARD ELEMENTS 318User defined object (on toolbar “Standard parts”).
CAD software WORKING WITH STANDARD ELEMENTS 319Command line: MCCUSTOMOBJ.
Tool User object makes it easy to group in objects nanoCAD and nanoCAD Mechanica23 into a single object. Custom objects support the ability to overlap other objects in the drawing.
1. Select the objects to create a custom object. 2. Specify part origin point. 3. Specify the drawing insertion and direction. 4. In the dialog box, set the value of the level of overlap of the object (for Level Z).CAD drawing WORKING WITH STANDARD ELEMENTS 320
When you create a custom object contour suppression, external contour of the object is automatically detected contour suppression external contour of the object. Subsequently, the control circuit is used when objects overlap on the drawing..
Custom objects support editing with standard tools nanoCAD Mechanica23.
Managing Dependencies
CAD drafting WORKING WITH STANDARD ELEMENTS 321Main menu: Mechanical – Standard parts – CAD software WORKING WITH STANDARD ELEMENTS 322Add constraint.
CAD drawing WORKING WITH STANDARD ELEMENTS 323Ribbon: Mechanical – Library – CAD drafting WORKING WITH STANDARD ELEMENTS 324Add constraint.
CAD software WORKING WITH STANDARD ELEMENTS 325Toolbar: CAD drawing WORKING WITH STANDARD ELEMENTS 326Add constraint ( “Standard parts”).
CAD drafting WORKING WITH STANDARD ELEMENTS 327Command line: MCCONSTRAINT.
In the dialog box Constraints:
CAD software WORKING WITH STANDARD ELEMENTS 328
In the dialog box set parametric and assembly (geometric) dependencies between database objects.
The window is divided into two parts:
Left – The child
Right – The parent object
Use CAD drawing WORKING WITH STANDARD ELEMENTS 3291-selected object and 2 were selected to the choice made in the drawing, respectively subsidiary and parent objects. After selecting an object in the corresponding half of the window, a list of parameters of the object, which includes:
· Property name · List surfaces (work surfaces) · The list object’s parameters · List of installed parametric relationships · List of installed assembly constraintsCAD drafting WORKING WITH STANDARD ELEMENTS 330
On two tabs depending Parametric and Assembly constraints established relationship between parent and child objects.
Parametric dependence connects the parameters of objects.
Assembly dependence binds workplanes objects.
Button CAD software WORKING WITH STANDARD ELEMENTS 331 New dependency. Allows you to create a new dependency
Button CAD drawing WORKING WITH STANDARD ELEMENTS 332 Delete dependency. Deletes the selected list dependence
When adding or editing button is activated depending CAD drafting WORKING WITH STANDARD ELEMENTS 333Save dependence, which allows you to save your changes.
Installing the parametric dependence
When installing the parametric constraints is associated parameters are recorded in the corresponding input fields located below the list object’s parameters. Selecting the link parameters by double-clicking on the corresponding parameters in the list.
CAD software WORKING WITH STANDARD ELEMENTS 334
Installing assembly according
To install the switch assembly according to the tab Assembly constraints.
Choose binding surface by double-clicking on the appropriate working plane from the list.
CAD drawing WORKING WITH STANDARD ELEMENTS 335
Selecting the plane can also be done visually in the drawing by clicking labelled plane and the linked marker indicating the working plane of the object.
CAD drafting WORKING WITH STANDARD ELEMENTS 336
The choice of method depends overlay using the buttons at the bottom:
CAD software WORKING WITH STANDARD ELEMENTS 337Axial and surface alignment
CAD drawing WORKING WITH STANDARD ELEMENTS 338Surface alignment
CAD drafting WORKING WITH STANDARD ELEMENTS 339Combination axis
CAD software WORKING WITH STANDARD ELEMENTS 340Direction
Choose mutual orientation related planes using the buttons:
CAD drawing WORKING WITH STANDARD ELEMENTS 341Counter-directional
CAD drafting WORKING WITH STANDARD ELEMENTS 342Codirectional
Button CAD software WORKING WITH STANDARD ELEMENTS 343 Bidirectional constraint. Enables two-way relationship in which a related parameter or surface of the parent object changes with appropriate changes to the child object.
Compound objects
CAD drawing WORKING WITH STANDARD ELEMENTS 344Main menu: Mechanical – Standard parts – CAD drafting WORKING WITH STANDARD ELEMENTS 345Connect objects.
CAD software WORKING WITH STANDARD ELEMENTS 346Ribbon: Mechanical – Library – CAD drawing WORKING WITH STANDARD ELEMENTS 347Connect objects.
CAD drafting WORKING WITH STANDARD ELEMENTS 348Toolbar: CAD software WORKING WITH STANDARD ELEMENTS 349Connect objects ( “Standard parts”).
CAD drawing WORKING WITH STANDARD ELEMENTS 350Command line: MCCONNECTTO.
This command is used to overlay preset assembly and parametric dependencies on objects in the drawing.
After running the command must specify.
1. Child object – an object that will be joining. 2. Parent object – the object to which you will attach the child object.Upon completion of the command will be imposed on the details of parametric and geometric constraints defined in their script..
Recognition graphics drawings
CAD drafting WORKING WITH STANDARD ELEMENTS 351Main menu: Mechanical – Recognition – CAD software WORKING WITH STANDARD ELEMENTS 352Symbol block recognition.
CAD drawing WORKING WITH STANDARD ELEMENTS 353Ribbon: Mechanical – Utilities – CAD drafting WORKING WITH STANDARD ELEMENTS 354Symbol block recognition.
CAD software WORKING WITH STANDARD ELEMENTS 355Toolbar: CAD drawing WORKING WITH STANDARD ELEMENTS 356Symbol block recognition (on toolbar “Recognition”).
CAD drafting WORKING WITH STANDARD ELEMENTS 357Command line: MCRECS.
Using commands recognition of graphic objects will significantly speed up the process of registration as the projections of old drawings and new, but made by hand without the use of any application.
Character Recognition is offered to carry out automatic or semi-automatic mode.
nanoCAD Mechanica 23 recognizes the following symbols and signs on the drawing:
· ymbols, text callouts; · formats; · specification sheets; · table.Call Team
By default, the toolbar “Character Recognition” is not displayed.
To invoke it, place the cursor pointer on the main toolbar nanoCAD Mechanica 23and click the right mouse button. In the context menu, click on “Recognition”.
You will see an additional toolbar:
CAD software WORKING WITH STANDARD ELEMENTS 358
CAD drawing WORKING WITH STANDARD ELEMENTS 359
Character recognition
CAD drafting WORKING WITH STANDARD ELEMENTS 360
Recognition formats
CAD software WORKING WITH STANDARD ELEMENTS 361
Recognition specifications
CAD drawing WORKING WITH STANDARD ELEMENTS 362
Table recognition
Automatic recognition
To perform automatic recognition of characters in the drawing context menu after recognizing any symbol.
Automatic character recognition requires checking the entire drawing, so it is not recommended for use in saturated drawings.
Recognize the main frame with the inscription enough to the source drawing contained within the Standard size, two contour lines and the title block.
Entries in the title block recognizable drawing are automatically entered in the dialog box title block, add additional fields and zones.
Recognition forms specifications
Information in the figure, placed on the forms specifications after recognizing transferred to Excel.
For correct recognition itself form the specification may be a block or drawn objects such as “Line”.
The text in the cells of the form specification – an object of type “text”.
Dialog “Overrides”
CAD drafting WORKING WITH STANDARD ELEMENTS 363Shortcut: ALT+RBM (when you hover over a line or shading standard element).
It overrides the style of the individual lines in a standard cell.
Sample call
1. Insert a standard element, such as I-beams.In the properties, select the rendition of “left view” and the type of display “view with a cut”.
CAD software WORKING WITH STANDARD ELEMENTS 364
2. Do not get fooled by the hatch and press ALT+RBM. The “Overrides” dialog box.
CAD drawing WORKING WITH STANDARD ELEMENTS 365
Options
Colour -changes the color of the line.
CAD drafting WORKING WITH STANDARD ELEMENTS 366CAD software WORKING WITH STANDARD ELEMENTS 367CAD drawing WORKING WITH STANDARD ELEMENTS 368
Line width – change the line width.
CAD drafting WORKING WITH STANDARD ELEMENTS 369CAD software WORKING WITH STANDARD ELEMENTS 370CAD drawing WORKING WITH STANDARD ELEMENTS 371
Hatch angle (degree) – controls the tilt hatch. The parameter is active only for the hatch.
CAD drafting WORKING WITH STANDARD ELEMENTS 372CAD software WORKING WITH STANDARD ELEMENTS 373CAD drawing WORKING WITH STANDARD ELEMENTS 374
Hatch step – changes hatching step. The parameter is active only for the hatch.
CAD drafting WORKING WITH STANDARD ELEMENTS 375CAD software WORKING WITH STANDARD ELEMENTS 376CAD drawing WORKING WITH STANDARD ELEMENTS 377
Hide object – it makes an invisible line. The other parameters are ignored.
CAD drafting WORKING WITH STANDARD ELEMENTS 378CAD software WORKING WITH STANDARD ELEMENTS 379CAD drawing WORKING WITH STANDARD ELEMENTS 380
If the setting “Show invisible lines” is “Yes”, then the line will be displayed with a color according to the setting of “Color of invisible lines”.
Override main lines
CAD drafting WORKING WITH STANDARD ELEMENTS 381Context menu: Override main lines (on the selected object).
CAD software WORKING WITH STANDARD ELEMENTS 382Command line: MCOVERRIDEMAINLT, OVERRIDEMAINLT.
Users sometimes need to make retrofit drawings that show both new and existing objects at the same time.
That is, for example, welding new fittings into an existing tank. In this case, the main lines of existing objects (fittings, hatches, bolts, shells, bottoms and any other elements of the base) should be depicted either as thin or dashed lines.
To change these parameters, use the “Override main lines” command.
1. Select the standard elements to override.
CAD drawing WORKING WITH STANDARD ELEMENTS 383
2. Call the “Override main lines” command. The “Overriding the main lines” dialog opens.
CAD drafting WORKING WITH STANDARD ELEMENTS 384
3. Specify the required parameters.
CAD software WORKING WITH STANDARD ELEMENTS 385
4. Click the “OK” button. The main lines of the selected objects will be overridden.
CAD drawing WORKING WITH STANDARD ELEMENTS 386
Dialog
CAD drafting WORKING WITH STANDARD ELEMENTS 387
Linetype – the parameter allows you to select the line type from the list: Solid or Dashed line.
Width – the parameter allows you to select the line thickness from the list.
Color – the parameter allows you to select the color of the lines.
Button CAD software WORKING WITH STANDARD ELEMENTS 388“Clear all redefinitions” – removes all previously made overrides, brings the selected objects to the default settings.
