Conversion options
Ribbon: Raster– Conversion> R2V Conversion Options
Menu: Raster – Convert> Conversion options
Command line: R2VSETUP
Raster selection and vectorization are configured using the R2V Conversion Options dialogue box. The main options are set in the Recognition and Options tabs. If text search and recognition algorithms used, then it is also necessary to configure options specified in the Texts tab described below in this chapter.
The thicknesses of the objects obtained during vectorization can be rounded to predefined values, as well as placed on different layers and assigned different colors. These operations are performed using the Separate tab.
Info: NanoCAD is a simple, low cost, and yet professional, CAD program for personal computer, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software ensures groundbreaking, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
