Break All Vectors at Point
Ribbon: Draw – Modify > Break All Objects at Point
Menu: Modify – Break All Objects at Point
Toolbar: Modify –
Command line: VCBREAKALLATPOINTCMD
The Break All Vectors at Point command breaks intersection objects (lines, arcs, polylines, splines and other vector objects) in the intersection point. Some closed objects (ellipse, circle, etc.) can’t be break at point.
Select objects or [?]: Select intersection object.
Specify break point: Specify an intersection point (s).
