Contour Lines Labels
Ribbon: Topoplan – Relief > Contour Lines Labels
Menu: Ground – Elevation > Contour Lines Labels
Toolbar: Elevation > Contour Lines Labels
Command line: NG_CREATE_CONTOUR_LABEL
The command creates a label (in form of block) at the specified location of the contour.
To create labels for contour lines:
1. Run the command.
2. If 3D visual style was set in a drawing, then a warning message appear at the command launch with the proposal to switch to 2D render mode. Agree for the right display of label elements.
3. In response to the prompt
Specify position of contour elevation label:
click on the contour line with enabled snap to create the Mtext object on the Contour lines layer with the enabled Hide background parameters to hide a contour area in the text insertion point.
It is not necessary to use an object snap: a label will be created on the contour line nearest to the cursor.
4. Several labels can be created in succession. Pressing ESC button ends the command.
Info: NanoCAD is a simple, affordable, and yet professional, CAD platform for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software provides innovative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, in case you like it
