Calculation wizard
CAD drafting ENGINEERING ANALYSIS 0Main menu: Mechanical – Design – Calculations – CAD software ENGINEERING ANALYSIS 1Calculations wizard.
CAD drawing ENGINEERING ANALYSIS 2Ribbon: Mechanical – Design – CAD drafting ENGINEERING ANALYSIS 3Calculations wizard.
CAD software ENGINEERING ANALYSIS 4Toolbar: CAD drawing ENGINEERING ANALYSIS 5Calculations wizard ( “Design”).
CAD drafting ENGINEERING ANALYSIS 6Command line: MCCALC.
Fundamental rules
1. Calculations wizard allows you to edit all the calculations are available in the file – regardless of the graphics platform. To create a new calculation required, specifying the desired type, click “New calculation”. 2. The calculation results can be displayed directly in the calculation manager. 3. The type and number of parameters displayed in the dialog can be edited by the user at his discretion. To do this, double-click in the right part of the dialog box cause the viewer to edit.By default, the dialog box takes the following form:
CAD software ENGINEERING ANALYSIS 7
When installing the mouse cursor on the name of the calculation are available additional options.
CAD drawing ENGINEERING ANALYSIS 8
Toolbar
CAD drafting ENGINEERING ANALYSIS 9Create – Activates the calculation type depending on the selected window.
CAD software ENGINEERING ANALYSIS 10Delete – Removes the created calculation
CAD drawing ENGINEERING ANALYSIS 11Open – Opens previously saved on the disk calculation
CAD drafting ENGINEERING ANALYSIS 12Save – Saves the selected calculation on disk in a file * .mcc
CAD software ENGINEERING ANALYSIS 13Edit – This command opens the window for editing the calculation results
CAD drawing ENGINEERING ANALYSIS 14
Upon activation, the report window, the user can enter their own value and remove unnecessary.
Default report templates for calculating gearing placed in a folder
C:\Program Files\Nanosoft\nanoCAD Mechanica 23\Reports Templates\
Calculation of gears
The calculation is made on the basis of GOST 21354-87 (hereinafter – the Standard) “Cylindrical gears involute external engagement for strength calculation.”. The standard establishes the basic design according to the definition of the contact strength of the active surfaces of the teeth and tooth strength at bending metal cylindrical involute external gear transmission for general industrial applications with source circuit in accordance with GOST 13755-81, modulus m / 1 mm, working with lubrication oil at peripheral speeds v<=25 m/s.
Designing gear can begin in any sequence. What to do in the first place – the calculation or drawing gear – it does not matter.
The wheels that were drawn without calculation, it is always possible to adjust the results of the calculation. All geometry is adjusted automatically.
Approaches to the design of the gear in nanoCAD Mechanica 23:
1. Draw gear without calculation by entering the wheel settings dialog. 2. To calculate the gear and the results of calculation render mesh. 3. To calculate the transmission stage and assign the result to the transfer were drawn without prior calculation. 4. Use the template file with the initial data on the calculated transmission gear stages and drawn by the circuit of the gearbox. By changing the raw data calculation, to update the geometry file template steps gears.Drawing wheels (gears) without calculating
We choose to base parts of the gear pattern.
CAD drafting ENGINEERING ANALYSIS 15
We define the insertion point and the direction of its rendering.
You can enter the desired design parameters designed wheels dialog. The default render wheel without calculation.
CAD software ENGINEERING ANALYSIS 16
CAD drawing ENGINEERING ANALYSIS 17CAD drafting ENGINEERING ANALYSIS 18 Personal application assembly dependencies on a pair of gearing on the calculated spacing.
1. We choose to base parts of the gear pattern. 2. We define the insertion point and the direction of its rendering. 3. Since the calculation is done, select the desired calculation from the dropdown list. 4. Specify which element engagement render on the results of the calculation (wheel or gear) and click OK. 5. After drawing one element command remains active. To complete it, click with the ESC key.CAD software ENGINEERING ANALYSIS 19CAD drawing ENGINEERING ANALYSIS 20 To assemble the wheels and gears on the calculated spacing options use gearing and Remove gearing.
After selecting a template nanoCAD Mechanica 23 prompts you to specify the insertion point and the direction of drawing of the selected type wheel.
If the drawing already has a shaft portion, which is supposed to place the wheel, the insertion point is automatically determined by the aperture of the shaft portion of the highlighted cursor pointer.
CAD drafting ENGINEERING ANALYSIS 21
Gear is regarded as an independent object, for which the specified power and kinematic characteristics of the input or output.
Gear is an element of the designed gear. Pre-selection is carried out of the engine is determined by the overall gear ratio is carried out by a breakdown of the gear ratio gear stage determined power and kinematic characteristics of the gears of the individual stages.
In the proposed algorithm, the requirements of GOST completely soaked.
According to the calculation results can be obtained:
· geometrical characteristics of the gear train designed; · data to monitor the accuracy of the gears; · data to estimate the gear strength (allowable and actual voltage as in the contact and bending endurance calculation teeth, and the teeth in the calculation of the maximum load on the action); · degree of loading gear on these kinds of stresses.Estimator (a program for calculating the gear) allows you to perform two types of calculations:
· designing new gear for a given load, durability, desired gear ratio and other parameters; · check the specified gear strength.In the first case, the estimator first transfer designs (in our version – on the basis of conditions to ensure contact strength), that is, defines all of its geometric characteristics, including module and spacing, and then to check on the strength of all kinds of stress.
In the estimator of the second embodiment is not used for design, but only for testing the strength of the transmission, the geometric characteristics of which are already known or pre-defined.
For the two types of calculations in the dialog box Calculations toothed cylindrical gear are two options provided for data input:
Each type has its own form of payment report with its source data and its own characteristics of presentation of calculation results as well as its report templates.
CAD software ENGINEERING ANALYSIS 22Library: Calculations – Spur gears – Cylindrical Gearing Strength Analysis
In what follows the parameters and characteristics related to the gear, given the index 1; relating to the wheel – the index 2.
The initial data are encouraged to use:
· typical transmission loading mode (GOST, features 32, p.106.) or load sequence diagram (GOST, features 14, p. 63); · the torque on the shaft of the wheel gear – T2, N * m (if the load is variable, then how current torque accepted most of long-acting); · Wheel speed – n2, min. – 1; · the gear ratio gear set – u; · the type of gears (spur, helical, herringbone); · tooth angle – CAD drawing ENGINEERING ANALYSIS 23; · offset coefficients source generating circuit – x1 and x2; · transmission type: reversible or irreversible. By reversing or non-reversing gear transfer meant a two-way or one-way load application; · term transmission service – Lh, h; · material and a method of chemical-thermal hardening of gear wheels and transmission calculated; · the location of the calculated gear in the drive according to the scheme in accordance with GOST, p. 58, fig. 13a.Enter the initial data for the design of the transmission by means of the dialog box, shown in figure:
CAD drafting ENGINEERING ANALYSIS 24
By clicking on the button “More …” open additional field data input for the reverse gear, the method of machining the tooth flank and its heat treatment.
CAD software ENGINEERING ANALYSIS 25
Initial data
Type of gears
The drop-down list of the gear types allows you to select one of three options: spur, helical, herringbone or wheel:
CAD drawing ENGINEERING ANALYSIS 26
Angle of teeth inclination
When choosing a helical or herringbone wheels in the “angle of the teeth” should enter a value in degrees of the desired angle of inclination of the tooth line in the recommended range (typically 8-22 ° for helical and 25-40 ° for chevron wheels).
If this field is left blank, the program installs by default a certain angle, which lies within the specified limits. Most often, this angle imposed by the previous calculation. It can be changed either directly or by subsequent adjustment calculation.
Ratio of gear transmission
The field is filled in accordance with the terms of reference and the expected characteristics of the engine.
Rotation frequency of driven gear shaft (1/min)
Torque moment of driven gear shaft (Nm)
Required resource (hour)
Divisibly of max moment of motor
Kinematical scheme
CAD drafting ENGINEERING ANALYSIS 27
Click on the field with the image of the kinematic scheme reveals nine schemes of gear reducers, from which you can choose the layout of the gear pair corresponding to the estimated case. Estimate the case highlighted in white.
Load conditions
Load conditions is selected from the dropdown list.
CAD software ENGINEERING ANALYSIS 28
Table of values of equivalence ratios for each loading mode:
CAD drawing ENGINEERING ANALYSIS 29
Check “With tooth head modification”
Check “Reverce transmission”
It makes active group of source data “” Reverse transmission “.
Koefficients of initial operating contour displacement by gear cutting
Number of teeth gearings per one revolution of gear
Group “Materials”
Materials of gears and their characteristics are selected from a drop down list or from the database.
CAD drafting ENGINEERING ANALYSIS 30 Go to the database by clicking on the appropriate button to the right of the selection grade of steel.
CAD software ENGINEERING ANALYSIS 31
Type of material selection group gears and wheels:
CAD drawing ENGINEERING ANALYSIS 32
For convenience, you can select to see comments to the selected material.
Group “Reverce transmission”
The group contains the following fields:
· Rotation frequenct of driven gear shaft · Torque moment of driven gear shaft (Nm) · Required resource (hour)Check “Transitional surface is polished”
Check “With tooth root inclusion”
Grinding of transitional surface conditins
Activity fields depends on the chosen material
CAD drafting ENGINEERING ANALYSIS 33
If the transition is made grinding surface of the teeth, the required grinding mode can be selected from the corresponding drop-down list.
Editing Material Database
The user can edit any of the selected characteristics of the material, but it should be borne in mind that some of them change must be accompanied by a change in the other. In particular, the limit of endurance in bending teeth, corresponding to the basic number of stress cycles CAD software ENGINEERING ANALYSIS 34 for normalized, improved nitrided and wheels, as well as the base value limit stress teeth flexural maximum load CAD drawing ENGINEERING ANALYSIS 35 for normalized and improved gear depends on the hardness of the teeth.
Therefore, changing the hardness of the wheel teeth with a chemical-thermal treatment, need to change their performance and durability. If you are not sure of the correctness of the total introduced to them changes, to edit the properties of the material is better to use filling material properties dialog box (see. below).
CAD drafting ENGINEERING ANALYSIS 36
The options available in the database, with the following designations are:
CAD software ENGINEERING ANALYSIS 37
Half product making
CAD drawing ENGINEERING ANALYSIS 38
Units of measurement of hardness.
CAD drafting ENGINEERING ANALYSIS 39
The choice of heat treatment of the material.
SIGMA_Flimb
The limit of endurance in bending teeth, corresponding to the basic number of stress cycles MPa.
Y_g
Factor which takes into account the impact of the transition surface grinding teeth (GOST, table. 13, p. 10.4).
Y_d
Factor which takes into account the effect of strain hardening or electrochemical treatment of the transitional surface of the tooth (GOST, table. 13, p. 10.5).
S_F
Calculated safety factor based on the bending resistance (GOST, table. 13, p. 11).
SIGMA_Fst
The safety factor in the calculation of the teeth on the maximum flexural load (GOST, table. 18, n. 2).
SIGMA_T
Yield gear material MPa.
H_O
Surface hardness of the teeth.
H_K
The hardness of the teeth of the core.
Updating and changing the base made by the three buttons located in the upper left Materials:
CAD software ENGINEERING ANALYSIS 40New material
CAD drawing ENGINEERING ANALYSIS 41Delete material
CAD drafting ENGINEERING ANALYSIS 42Edit
For example, click on the New button opens a dialog box material properties of the material. For the correct insertion of a new material in the base must be filled in all the fields of the window.
Entering a new material
CAD software ENGINEERING ANALYSIS 43
In the field of material input parameters are copied to the properties of the previously selected metal. Thus, the user is given the opportunity to create its database in relation to specific production and technological capabilities of the enterprise.
All fields of the material properties of a window can be filled by the user immediately. However, given that in accordance with GOST limits contact endurance and stamina for bending at various thermochemical treatment of steels defined by different dependencies, at this stage it is advisable to fill the database go to the next dialog box, activating the button Select …
CAD drawing ENGINEERING ANALYSIS 44
The corresponding filling material properties dialog box (the button Select …) allows you to select the characteristics of aggregated groups of materials and thermochemical treatment (upper left field of the window).
CAD drafting ENGINEERING ANALYSIS 45
These can then be clarified in relation to specific groups of steels (bottom left margin of the window) and see the calculated values ??of the respective limits of endurance (Recommended field).
We have already said that strength characteristics of the gears of the normalized and improved, as well as nitrided steels depend on the hardness of the teeth. Therefore, in determining the strength characteristics of gears exposed to these types of chemical and thermal hardening, in advance, before calling the dialog box Filling material properties in the Properties dialog box material required hardness of the teeth must be installed.
In this case, the parameters CAD software ENGINEERING ANALYSIS 46 and CAD drawing ENGINEERING ANALYSIS 47 in the “Filling the properties of the material” will match hardness adopted.
Autofill material properties
If you agree with the results, it sets a flag in the autocomplete field.
CAD drafting ENGINEERING ANALYSIS 48
The calculated parameters are transferred to the corresponding open field characteristics of the particular material. These fields can be filled manually, if desired.
Removing material from the base
CAD software ENGINEERING ANALYSIS 49
Selecting material removal cancel command does not work. To return to the base material should be re-entered.
Edit the properties of the material
CAD drawing ENGINEERING ANALYSIS 50
When you select the Edit window Materials Database of materials displayed earlier submitted Material Properties dialog box.
In the Comment field user input, one way or another characterizing the material.
CAD drafting ENGINEERING ANALYSIS 51
CAD software ENGINEERING ANALYSIS 52
This dialog shows all the parameters of how the raw data and calculate results. By clicking the Back button, you can return to the dialog box to make changes to the initial calculation data.
CAD drawing ENGINEERING ANALYSIS 53Library: Calculations – Spur gears- Strength calculation of spur gearing
Operation of the second embodiment does not use calculators for design, but only for testing the strength of the transmission to the known or predetermined geometrical parameters.
Checking calculations has its own form of the report and data input. In all other respects similar to the method described above.
CAD drafting ENGINEERING ANALYSIS 54
CAD software ENGINEERING ANALYSIS 55
From this window, click on the icon CAD drawing ENGINEERING ANALYSIS 56 You can go to the Calculation wizard. If any payments were previously carried out, their results can be accessed using the drop down menu.
CAD drafting ENGINEERING ANALYSIS 57
If the entered spacing does not match the entered calculation parameters, then when it changes you will receive a message which will be offered options:
· Continue with the correction of the calculation specified center distance · Continue with the entered payment data (calculation results may be incorrect)CAD software ENGINEERING ANALYSIS 58
Initial data
Type of gears
CAD drawing ENGINEERING ANALYSIS 59
Distance between axes
Pitch
Degree of accuracy GOST 1643-81
Kinematical scheme
CAD drafting ENGINEERING ANALYSIS 60
The two-stage and three-stage gear units can be run on deployed or coaxial. In simple circuits deployed, each stage consists of a pair of gears. The disadvantage of such schemes – an uneven load distribution between the bearings, so that the resulting deformation of shafts occurs the load concentration along the length of the tooth, causing the need for a shaft with high rigidity.
This disadvantage is eliminated by using bifurcated stages. Preferably in the two-stage gear as forked use a high-speed, and in the three-stage – the intermediate stage.
The large width of a low-speed stage in these cases does not cause a significant load concentration along the length of the tooth due to the symmetrical arrangement of gears with respect to the supports.
Load conditions
CAD software ENGINEERING ANALYSIS 61
CAD drawing ENGINEERING ANALYSIS 62
Group “Materials”
CAD drafting ENGINEERING ANALYSIS 63 Go to the database by clicking on the appropriate button to the right of the selection grade of steel.
CAD software ENGINEERING ANALYSIS 64
CAD drawing ENGINEERING ANALYSIS 65
CAD drafting ENGINEERING ANALYSIS 66
CAD software ENGINEERING ANALYSIS 67Calculation wizard: Bevel Gearing Strength Analysis.CAD drawing ENGINEERING ANALYSIS 68Library: Calculations – Bevel Gears – Bevel Gearing Strength Analysis
CAD drafting ENGINEERING ANALYSIS 69
CAD software ENGINEERING ANALYSIS 70Calculation wizard: Geometric Calculation of Bevel Gearing.
CAD drawing ENGINEERING ANALYSIS 71Library: Calculations – Bevel gears – Geometric Calculation of Bevel Gearing
Calculation of the geometric parameters and the conical gearing elements can be made based on user input (checking the strength of finished transmission) or on the basis of the strength calculation.
CAD drafting ENGINEERING ANALYSIS 72
Static beam calculation
CAD software ENGINEERING ANALYSIS 73Main menu: Mechanical – Design – Calulations – CAD drawing ENGINEERING ANALYSIS 74Static beam calculation.
CAD drafting ENGINEERING ANALYSIS 75Toolbar: CAD software ENGINEERING ANALYSIS 76Calculation beams (toolbar “MCS Calculations”).
CAD drawing ENGINEERING ANALYSIS 77Command line: MCBEAM.
CAD drafting ENGINEERING ANALYSIS 78Library: Calculations – Loads – Beam.
CAD software ENGINEERING ANALYSIS 79Library: Calculations – Loads – Calculations – Beam calculation (applied to the finished beam affixed to the supports, loads and moments, see. Calculation).
CAD drawing ENGINEERING ANALYSIS 80Calculation wizard: Baem calculation (applied to the finished beam affixed to the supports, loads and moments, see. Calculation).
This command is used to calculate the strength of the direct beam of constant cross-section.
After selecting the command a dialog box opens beam calculation.
1. On the left side of the dialog box, select the cross-section of the beam. 2. Right set sectional dimensions and length L beams. For visual selection of the beam length, click CAD drafting ENGINEERING ANALYSIS 81Dynamic input at the bottom of the dialog box. 3. Enter the physical characteristics of the material and the cut rotation. 4. Specify moment and the loads acting on the beam.Setting section
There are three ways to specify the section:
CAD software ENGINEERING ANALYSIS 82
Standard geometric cross section (e.g., triangle).
CAD drawing ENGINEERING ANALYSIS 83
Rolled metal base elements of nanoCAD Mechanica 23 (e.g, I-beam GOST 8239-89). To use the base when calculating the beams need to set a Class 725.
CAD drafting ENGINEERING ANALYSIS 84
Arbitrary section defined by the user.
Sizing is carried out in several ways:
· Click inside the closed area. Automatically determined by the outer contour of the closed area and the region is added to the set. · Clicking on a closed polyline or circle. Added to the area bounded by a circle or polyline · Reselection area removes it from the set for the calculation of the cross section.After selection of the drawing section in the dialog box Beam calculation appears custom cross-section:
CAD software ENGINEERING ANALYSIS 85
Change the name of the custom section by selecting it and clicking the left mouse button on the title.
Delete a custom section of the list is made by pressing delete.
For the standard section of the database items, choose Type size from the dropdown list.
CAD drawing ENGINEERING ANALYSIS 86
Beam Load and moments
1. In the dialog box, double-click the desired type of load or moment.CAD drafting ENGINEERING ANALYSIS 87
2. Select insertion point or the load bearing on the beam. At the time of selecting the insertion point move the cursor to the beam to install dependencies.CAD software ENGINEERING ANALYSIS 88
3. Set the parameters or load bearing in the dialog box. · SupportPoint – the distance from the starting point to the point of insertion beam bearing in millimeters. Use keys to select the type of support.
· Concentrated loadPosition – the distance from the starting point to the point of insertion beam load, mm.
Value – the value component of the load in the selected direction, H.
Point – the distance from the insertion point to the point of load application of the load in the selected direction, mm.
Diagram on the left side of the dialog box explains the meaning of the input parameter.
Tabs on the top of the window are used to select the coordinate system in which the values are set:
CAD drawing ENGINEERING ANALYSIS 89 Rectangular CAD drafting ENGINEERING ANALYSIS 90 Spherical CAD software ENGINEERING ANALYSIS 91 Cylindrical · Distributed loadPosition – the distance from the starting point to the point of insertion beam load, mm.
Length – length of the section, which is attached to a distributed force, KN/mm.
In input fields, set the value component of the load in the selected direction, H.
CAD drawing ENGINEERING ANALYSIS 92 Rectangular CAD drafting ENGINEERING ANALYSIS 93 Spherical CAD software ENGINEERING ANALYSIS 94 Cylindrical · MomentsDiagram on the left side of the dialog box explains the meaning of the parameters.
X, Y, Z – the components of the bending moment , KN*m.
C – distance from the starting point to the point of insertion beams torque , mm.
Calculation
Click CAD drawing ENGINEERING ANALYSIS 95Calculate beam at the bottom of the dialog box to perform the calculation.
CAD drafting ENGINEERING ANALYSIS 96
Table of results of calculating comprises calculating the maximum deflection and stress values as well as the distance from the starting point of the beam to a point at which the maximum of each parameter.
To insert a drawing graphs strain and effort to select the desired type of graph for each feature:
CAD software ENGINEERING ANALYSIS 97 CAD drawing ENGINEERING ANALYSIS 98
Button CAD drafting ENGINEERING ANALYSIS 99Apply adds graphics drawing.
CAD software ENGINEERING ANALYSIS 100
Button CAD drawing ENGINEERING ANALYSIS 101 Save Report. Stores the results of the calculation of the beam to an external file.
Button CAD drafting ENGINEERING ANALYSIS 102 Calculate value. Opens Meaning, in which parameters are calculated at an arbitrary point of the beam.
CAD software ENGINEERING ANALYSIS 103
Button CAD drawing ENGINEERING ANALYSIS 104Export diagrams. Sell calculation results in a table in Construction Site 23. After selecting the command, specify the insertion point on the drawing table.
CAD drafting ENGINEERING ANALYSIS 105Main menu: Mechanical – Design – Calculations – CAD software ENGINEERING ANALYSIS 106Calculate section characteristics.
CAD drawing ENGINEERING ANALYSIS 107Toolbar: CAD drafting ENGINEERING ANALYSIS 108Calculate section characteristics (toolbar “Calculations”).
CAD software ENGINEERING ANALYSIS 109Command line: MCGCS.
This command is used to calculate the geometric characteristics of the complex cross-sections with respect to arbitrary axes.
Calculation procedure
1. Call command. 2. In the drawing, then click the area closed by one of the ways: · Clicking inside a closed area. Automatically determined by the outer loop of the closed area, and the area is added to the set. · Clicking on a closed polyline or circle. Adds the area bounded by polyline or circle.CAD drawing ENGINEERING ANALYSIS 110CAD drafting ENGINEERING ANALYSIS 111
Note:
Repeated selection of the field deletes it from the set to calculate the cross-section.
3. Complete the selection by clicking the right mouse button or the Enter key. 4. Specify the origin point or [central axis]. If you select the “central axis”, the point of origin is automatically set in the center of mass of the cross section with an angle of rotation equal to 0 (step 5 is skipped).CAD software ENGINEERING ANALYSIS 112
5. Specify the angle of rotation of the coordinate system.CAD drawing ENGINEERING ANALYSIS 113
6. In the dialog box “Geometric section properties” Adjust the characteristics included in the summary table of the results.CAD drafting ENGINEERING ANALYSIS 114
For each characteristic, you can customize your format (except weight), and the accuracy of the unit.
CAD software ENGINEERING ANALYSIS 115
To calculate the weight you need to open an additional menu “Mass calculation on section”, which indicate the product density and length. When you specify the length of the need to expose the units. When you specify the density, you can use the base materials, by clicking on the button CAD drawing ENGINEERING ANALYSIS 116“Material selection”.
Customized settings display characteristics (size, precision, units) stored for later calculations sectional characteristics. To return to the default settings, press the button CAD drafting ENGINEERING ANALYSIS 117“Load default settings”.
7. Click “OK” in the dialog box and enter the drawing an insertion point of the table with the calculated parameters.CAD software ENGINEERING ANALYSIS 118
After the calculation is added to the drawing object nanoCAD Mechanica 23, comprising a cross-section schematic outline and the main central axis. The lengths of the axes are proportional to the values of the corresponding axial moments of inertia.
Fastening calculation
CAD drawing ENGINEERING ANALYSIS 119Main menu: Mechanical – Design – Calculations – CAD drafting ENGINEERING ANALYSIS 120Fastening calculation.
CAD software ENGINEERING ANALYSIS 121Ribbon: Mechanical – Design – CAD drawing ENGINEERING ANALYSIS 122Fastening calculation.
CAD drafting ENGINEERING ANALYSIS 123Toolbar: Calculations – CAD software ENGINEERING ANALYSIS 124Fastening calculation.
CAD drawing ENGINEERING ANALYSIS 125Command line: MCBOLTDESIGN.
Verification calculation to determine the admissibility of the selected thread for the specified load conditions.
The basis, when checking calculations bolts adopted methodology contained in the textbook “Kuklin NG, Kuklin GS machines Details – M .: Vyssh.shk., 1987”.
In calculating the user is able to take into account the recommendations of “GOST 1759.4 – 87 Bolts, screws and studs Mechanical properties and test methods.”.
When you call the command, a dialog box “Calculation check bolt”. By controlling the arrows in the graphic menu, select the version of the calculation.
1 variant – The connection is tightened during assembly, there is no external load.
CAD drafting ENGINEERING ANALYSIS 126
2 variant – Compound loaded transverse force.
CAD software ENGINEERING ANALYSIS 127
3 variant – Connections are tight and loaded external axial tensile force.
CAD drawing ENGINEERING ANALYSIS 128
Depending on the options available to calculate the various parameters.
Note:
The result of the calculation is the message in the “Results of calculation” on the sufficiency of the bond strength.
Furthermore, in the “calculation results are” options are displayed:
Max. valid thread diameter (mm) – inner diameter of the thread selected bolt;
Current thread diameter (mm) – the calculated internal diameter.
If the first parameter is greater than the second, the strength is sufficient.
Dimension chains
Teams of calculating dimensional chains are located in the Object Manager nanoCAD Mechanica. To access it you need to switch to the “Dimension chains” panel object manager nanoCAD Mechanica.
· Fundamental rules · Calculation methods · Icons tree calculation · Toolbar · The sequence of calculationFundamental rules
It proposed two methods of calculation: minimum-maximum method and the probabilistic method.
Measures involved in the calculation may be specified as one or several separate drawings.
The project is monitored dynamically link with the size of the drawings. If the size is different from the drawing or missing from the drawing, it will be highlighted in bold.
Calculated closing unit contains the calculated values of the nominal value, the upper ES and lower EI deviations. All dimensions are displayed in the 1: 1 scale.
In edit mode, you can create new master links, remove the entire branch graph, edit size, surface combine different branches (the movement of the nodal points “grips”).
At the end of the table shows the calculation of the calculated deviations closing units.
It supports only linear dimensional chains.
Calculation methods
Maximum / minimum
Nominal closing link:
CAD drafting ENGINEERING ANALYSIS 129
n – number of units, except the locking.
The upper limit deviation of the closing unit:
CAD software ENGINEERING ANALYSIS 130
Lower limit deviation of the closing unit:
CAD drawing ENGINEERING ANALYSIS 131
Probabilistic
CAD drafting ENGINEERING ANALYSIS 132
ES – upper deviation;
EI – lower deviation;
The upper and lower deviation of the closing level will be symmetrical:
CAD software ENGINEERING ANALYSIS 133
t – risk ratio.
CAD drawing ENGINEERING ANALYSIS 134
P – risk percentage;
?2 – coefficient taking into account the law of distribution of real denominations.
Adopted 1/9 for the Gaussian distribution, for the distribution of 1/6 and 1/3 Simpson for uniform distribution.
Note:
When calculating the maximum / minimum denomination of an unknown can be set on a single link, the upper deviation of the unknown – on the other, the lower – in the third. The probabilistic method such chain is not counted.
CAD drafting ENGINEERING ANALYSIS 135 Project
Group size may contain several cycles of size.
CAD software ENGINEERING ANALYSIS 136 View thumbnails while editing the graph.
CAD drawing ENGINEERING ANALYSIS 137 Drawing
Group sizes, taken from a drawing. Path Drawing dropped, compared to only a name, that is the size of the C: \ Work \ Drawing1.dwg and C: \ Acad \ Drawing1.dwg will be placed in the same group “Drawing1”.
CAD drafting ENGINEERING ANALYSIS 138 Dimension
Dimension added to the drawing.
Next to the icon indicates the value of the size tolerances. Instead, you can enter any name (for example, the width of the bearing).
The value of the dimension can be viewed in a tooltip. If the dimension of the drawing was linked text below the dimension line, its name will be assigned automatically. To display the nominal, enter an empty name.
The dimension can be edited by double-clicking or from the context menu.
CAD software ENGINEERING ANALYSIS 139
CAD drawing ENGINEERING ANALYSIS 140 List of adjacent dimensions
The icon reflects the relative position of a given size (blue rectangle) and the adjacent (green rectangle).
CAD drafting ENGINEERING ANALYSIS 141 Unknown closing link
You can add a calculation for editing or drawing a graph by adding the size in which the value and / or deviations are “?”. It contains a list of increases CAD software ENGINEERING ANALYSIS 142 or decreases CAD drawing ENGINEERING ANALYSIS 143 dimensions (presumably).
CAD drafting ENGINEERING ANALYSIS 144 Switching link
It contains the calculated values of the deviations:
· face value CAD software ENGINEERING ANALYSIS 145; · upper deviation CAD drawing ENGINEERING ANALYSIS 146 ES; · lower deviation CAD drafting ENGINEERING ANALYSIS 147 EI.Note:
When you edit or delete any dimension calculated counting all units nulled.In project dynamically tracked due to the size on drawings. If dimension different from the drawing or missing from the drawing, it will be highlighted in bold fonts. Again take the value from the drawing context menu (How drawing).
Toolbar
CAD software ENGINEERING ANALYSIS 148 Create calculation
If the button is not available, were selected to be the calculation start or finish editing the graph.
The project can be any number of calculations. They are translated independently. By default, a calculation is named “New”.
CAD drawing ENGINEERING ANALYSIS 149 Open project
Projects are stored in a special format SPJ. If an existing project is not saved, it will be lost. Warnings are not provided.
Project files can be transferred to other folders on other machines. The relative path from the project file to the file associated drawings should not be modified so as not lost contact with the size of the project in the drawings.
CAD drafting ENGINEERING ANALYSIS 150 Save project
CAD software ENGINEERING ANALYSIS 151 Save project as…
CAD drawing ENGINEERING ANALYSIS 152 Add dimensions
From the selected objects based on the current filter will be selected either all or only the horizontal or only the vertical dimension. In the column all sizes will be rotated horizontally.
CAD drafting ENGINEERING ANALYSIS 153 Change filter
Setup select the type of dimensions (horizontal, vertical).
CAD software ENGINEERING ANALYSIS 154 Start/finish editing
The beginning and the end of the calculation of dimensional chains. This command displays the current drawing on the graph for the current calculation.
Pressing will clear the graph with the drawing and will in the calculation of the changes.
In edit mode, you can create new master links, remove the entire branch graph, edit size, surface combine different branches (the movement of the “grips”).
CAD drawing ENGINEERING ANALYSIS 155 Set to drawing
Makes changes made in the current account, the original drawings. Warnings are not provided!
CAD drafting ENGINEERING ANALYSIS 156 Get from drawing
Fixes dimension values to those given in the drawings.
CAD software ENGINEERING ANALYSIS 157 Calculate chain
Calculates all master links the current calculation.
CAD drawing ENGINEERING ANALYSIS 158 Create report
It puts the current drawing table the report and the distribution schedule tolerances.
CAD drafting ENGINEERING ANALYSIS 159 Closing link
Adds closing link. The command is only active during editing of the graph. After pressing need to sequentially select two surfaces of one or more branches of the graph (in the drawing).
CAD software ENGINEERING ANALYSIS 160 Non-specified limiting tolerancies
CAD drawing ENGINEERING ANALYSIS 161
Sets limiting tolerancies for unspecified tolerances. Limiting tolerancies is selected from the drop down menu.
CAD drafting ENGINEERING ANALYSIS 162 Calculation method
Accurate (high / low) and probabilistic.
CAD software ENGINEERING ANALYSIS 163
Risk – the probability that the real value of size does not provide a closing link in getting the calculated border. The possible values are from 32% to 0.001%. Recommended – 0.01%.
CAD drawing ENGINEERING ANALYSIS 164
The law of distribution of real values of size. From left to right: a normal distribution (Gaussian), triangular (Simpson) and linear (uniform).
If the law is unknown, it is recommended to take a linear distribution.
CAD drafting ENGINEERING ANALYSIS 165 Help…
1. By clicking on the icon “Create calculation” in the browser creates a folder sizes. By default, it is named “New”.CAD software ENGINEERING ANALYSIS 166CAD drawing ENGINEERING ANALYSIS 167
2. After clicking on the icon CAD drafting ENGINEERING ANALYSIS 168 “Add dimensions” the drawing must specify the dimensions involved in the calculation.CAD software ENGINEERING ANALYSIS 169
Information on the selected size appears in the browser.
3. Press CAD drawing ENGINEERING ANALYSIS 170 “Start/finish editing”. 4. Becomes available team CAD drafting ENGINEERING ANALYSIS 171 “Closing link”. Enter the drawing the locking unit (multiple master links). 5. After selecting press the trailing links CAD software ENGINEERING ANALYSIS 172 “Start/finish editing”. The information in the browser changes.CAD drawing ENGINEERING ANALYSIS 173
6. CAD drafting ENGINEERING ANALYSIS 174Calculate chain. The browser displays the results of the calculation.CAD software ENGINEERING ANALYSIS 175 The calculation results are displayed in a table in the drawing by clicking on the icon “Create report”.
