Copy with Base Point
Ribbon: Home – Clipboard > Copy With Base Point
Menu: Edit – Copy With Base Point
Hotkeys: CTRL+SHIFT+C
Command line: COPYBASE
This command copies the selected objects and places a copy of them on the clipboard. When copying, a base point is specified and it is used to insert a copy of the objects into the document.
Command option:
? | Starts additional options for objects selection. |
Select objects or [?]: | Select objects, press ENTER to finish selection |
Specify base point: | Specify a point. |
