Add vertex
Ribbon: Topoplan – Modify TIN > Add vertex
Menu: Ground – Editing TIN > Add vertex
Toolbar: Editing TIN > Add vertex
Command line: NG_MESH_VERTEX_ADD
The command adds a new vertex to the existing surface (Submesh or Polyface mesh).
To add a vertex:
- Run the command.
- In response to the prompt in the command line, select Submesh or Polyface mesh:
Specify new vertex position - Click cursor inside a mesh triangle to add a new vertex in the specified place. A vertex can be added with a reference to some objects.
Surface before adding a vertex Surface with added vertex
- Several vertices can be added in succession. Pressing ESC button ends the command.
Info: NanoCAD is a user friendly, low cost, and yet powerful, CAD freeware tool for PC, that delivers a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our tool supports creative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
