Color reduction
Ribbon:Raster– Processing> Color Reduction
Menu: Raster – Processing the raster > Color Reduction…
Command line: COLORREDUCTION
The procedure for reducing the number of colors is the same as for separating by color described in the previous section. The only difference is that you do not need to define the category names, since the procedure for reducing the number of colors does not create additional layers.
The procedure is set up in the same way as in the separation procedure. The purpose and functions of elements of this dialog box are identical to the purpose and functions of the elements in the Color Separation dialogue box.
Info: NanoCAD is an easy-to-use, affordable, and yet powerful, CAD freeware tool for Windows, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
