Erase
Ribbon: Home, Draw – Modify > Erase
Menu: Modify – Erase
Toolbar: Modify –
Toolbar: Main –
Command line: E, ERASE, DELETE
This command deletes objects from the document.
The Erase command is also available in the context menu.
Selected objects can be deleted by pressing the DEL button on the keyboard.
Select objects or [?]: Select objects.
Select objects or [?]: Continue selection of objects or press Enter to finish the command.
Info: NanoCAD is a simple, inexpensive, and yet professional, CAD app for PC, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software ensures innovative, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
