Symbols Tab
The Symbols menu tab is designed to display nanoCAD symbols.
Dimensions
Setting dimensions display parameters of nanoCAD. Allows you to change the layer into which new and copied dimensions, dialog settings, etc. are automatically inserted.
Layer
Allows you to select the layer on which the new and copied dimensions will be placed by default.
Apply layer for all new dimensions
When the option is enabled, the copied dimensions will be placed on a drawing layer selected for dimensions. When the option is disabled, dimensions are placed on the current layer.
Ordinate dimensions
Controls built-in ordinate dimensions, can take ISO and GOST values. When the ISO option is enabled, the ordinate dimensions of the ISO standard built into the nanoCAD platform are used. When the GOST option is enabled, the ordinate dimensions of nanoCAD are used.
Left according the GOST, right – to ISO
Show dialog for new dimensions
Controls automatic opening the dimensions dialog.
Arrows in chains
Replaces the arrows used in nanoCAD in dimensional chains. It is possible to replace with serifs, dots, or not replace at all.
Notes
Notes display options. Allow you to change the size of text, arrows, type of pointers, etc.
Invert oblique arrow
Allows you to select the direction of oblique arrow.
Show dialog before inserting the object
When the option is enabled, it shows insertion box before inserting a leader.
Align text line by current UCS
When the option is enabled, the text line is rotated in the direction of the right coordinate system.
Save text in dialogs
When the option is enabled, earlier inserted text remains in the insertion field when inserting the next leader.
The rest of options allow for changing dimension of text, pointers, line thickness, location layer, color, etc.
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD app for PC, that provides a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool ensures innovative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
