Import from LandXML
Ribbon: Topoplan – Import/Export > Import from LandXML
Menu: Topoplan – Import/Export > Import from LandXML
Toolbar: Import/Export > Import from LandXML
Command line: NG_IMPORT_LANDXML
The command allows you to import a surface from the LandXML format. As a result, a Mesh object will be created in a drawing
LandXML is a popular format for exchanging data with other applications. In nanoCAD it is possible to import and export surface data using LandXML version 1.2 format.
After running the command, a standard file selection dialogue box will open. Choose XML file and click OK. The command options will be displayed on the Properties toolbar:
Xml units | Displays the units in which XML file was saved. |
Dwg units | Displays the units in which it is required to display objects from XML file. If drawing units are meters, and the Dwg units option is set in meters, then objects from a file will be imported without scaling (1:1). |
Geodetic CS | As in the geodetic coordinate systems (as opposed to the generally accepted rectangular Cartesian) the X axis is directed to the north, and the Y axis – to the East, for the correct import of object from XML file, it is required to specify the parameter value – Yes. If you specify No, X and Y coordinates will reverse places during import. |
Info: NanoCAD is a user friendly, affordable, and yet powerful, CAD application for PC, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports innovative, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
