Copy layout
Ribbon: Layout – Layouts > Copy Layout
Layouts Manager dialog: Copy layout
Command line: COPYLAYOUT
This command copies all parameters and content of layout to the new layout.
The command offers to copy the last active layout by default:
Enter name of layout to copy :
To confirm, press ENTER, to copy another layout, input its name in the command line and then press ENTER.
Upon the prompt in the command line Enter name of layout to copy – specify the name for a new layout and press ENTER. If the name is not specified, the copy is assigned with the name of initial layout with the number (N), for example, А4 (2). Where (N) is a sequence number of the copy being created.
If the name being specified matches the name of an existing layout, a prompt is displayed in the command line with a choice of action:
Layout “A4” is exist. Replace it? or [Yes/No]:
ATTENTION! Selecting the name of an existing layout (Yes option) will replace all preset parameters and contents of this layout with the parameters and contents of the copied layout.
No option will interruot the copy process.
Info: NanoCAD is an easy-to-use, inexpensive, and yet professional, CAD application for Windows, that provides a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software provides progressive, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, if you like it.
